Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-02-2004, 04:04 PM
Ulnv4ever Ulnv4ever is offline
Adjusting the idle speed
I have a 96 integra, non-vtec. the idle is around 500 which is kind of low. I am trying to adjust it. i first disconnected the idle sensor, and adjusted the idle to around 750, by turning the screw. but after i connect the sensor back on, the idle goes back to 500. does anyone know if i am doing it wrong? thankx.
Old 06-30-2004, 06:55 AM
ManOnTheGo's Avatar
ManOnTheGo ManOnTheGo is offline
If you're following the Chilton book, you'll need to reset the ECU after adjusting the idle screw.
You can do this by disconnecting the battery for 15 seconds.
The best way to adjust the idle is by measuring the voltage on the Throttle Valve Position sensor (it varies from 0.32V/0.45V at closed/idle up to 5 volts when fully open). Don't disconnect the plug from the throttle body when measuring.
Before adjusting the valve, measure the voltage on the Throttle Valve Position Sensor (professionaly set at the factory). If you've already adjusted the idle, find out the voltage value from Acura or from someone who has the same car.
Green is Ground.
One of the wires are a constant 5 volts.
The other wire varies in voltage (you should measure this with respect to the ground cable).
How to adjust the idle stop screw on the throttle body tlknv Forester 0 01-26-2010 05:11 PM
adjusting the idle speed subhelix Century 0 08-17-2006 11:12 AM
adjusting the idle on the zc 91CRXTC '88 - '91 Civic | CRX | Wagon | Shuttlee 1 10-07-2005 05:44 PM
How to adjust cold idle speed probell Ranger | Courier 3 11-30-2004 03:59 PM
how to adjust the idle barrem23 Accord/TSX/Accord Hybrid 4 09-02-2003 10:43 PM
