Old 01-02-2004, 11:19 AM
dannieolie dannieolie is offline
Wire Problems!!!!!!
hey i'm having trouble with my 91 accord ex. I'm putting in a kenwood kdc-322 head unit. The trouble is that i dont know where the honda's wires from the harness go to( i don't have a manual). The reason i'm not using an adapter kit is because the front speakers keep fading in and out around turns so i think that the wires might have a been severed or messed up. I'll be running new speaker wire to all the speakers. The speaker wires will be taken care of out of the harness; i know which the battery, the ignition, and the ground are; i have just two wires left. I have a power antennae with the car so i'm sure one or both go to it i just don't know which. Lastly the kenwood's harness has two wires coming out that aren't speaker or battery/ground/ignition ONE IS LABELED "P. CONT." THE OTHER IS LABELED "ANT. CONT." Please any help would be great!!!!!
sincerely DAN
Old 01-02-2004, 04:25 PM
looking4_12s_run looking4_12s_run is offline
Re: Wire Problems!!!!!!
You can probably find the wire map in the manual. You can find the manual here =>
http://www.kenwoodusa.com/support/ma...productId=2488
I hope its not a stolen radio, cause only dickwad-motherfucking-cheap-wannabe-looser-spoiled-shitfaced-pimpled-smelly-bitches
support the theft of hard earned material.
On that note...
I strongly suggest you get yourself a harnes if you want a reliable signal. If you will be changing fuses like crazy. The pins are too close together not to have insolation around each signal. When one signal touches the other. zzzzapp. Whats the big deal anywayz a harness isl like $15 at a stereo shop and all the colors will match. OR you could keep hacking away at those wires till you have to add extensions.
ant. cont. is for antenna control (you dont have power antena)
p.cont . is for amps and such. ie. power control. It tells your amp to turn off and on at the same time as your radio.
Good luck.
For those who dont get us, go spend 50 grand on your status symbols.
For half the price, we'll be passing you by in custom style at high speeds, expressing our selves and teaching the world not to conform to its corrupt ideals of rich will be rich and you should buy this.
We will demonstrate the intelligence of desire and swim in the success of doing what you said we couldnt.
Screeachhhhhhh.... and im gone.
wiring short in sterring colum? danielgast46 F Series 5 03-23-2009 07:35 PM
Help Please, wiring issue, just installed new audio deck, having other wiring problem daniel_e_10 Car Audio 3 03-23-2008 02:26 AM
idle problems/stereo wiring problems cruelsense Elantra | Avante 1 10-12-2005 11:54 AM
wiring problem? window problem? rad88 Cherokee 5 09-22-2004 12:56 PM
Brake Line and ABS Wire Problems with lifts warmonger Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 09-07-2001 10:46 PM
