Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-02-2004, 08:41 AM
jasonpop jasonpop is offline
Replacing a Trans in 95 SL2
I have a 95 SL2 with 92K miles. Three weeks ago I had it checked out and there was metal in the filter and trans oil. I am not willing to put $1500-2000 into this thing. I can get a junkyard trans for $250-350. I am actually considering doing this myself.
Does anyone know where I can a book/information on how to do this???
I am fairly confident that I can do it but i would like a little help.
Old 01-05-2004, 04:17 AM
wolfmanS wolfmanS is offline
Send a message via AIM to wolfmanS Send a message via Yahoo to wolfmanS
Re: Replacing a Trans in 95 SL2
http://www.saturnfans.com
Old 06-26-2004, 09:42 PM
wanda wanda is offline
alldata diy is a good source for any kind of problem you are having and has any r&r info u need your 1st subscriction will cost u 29.95 but it will save u big bucks in the long run.go to www.alldata.com and enter under the diy for any vehicle on the market including saturns
Old 07-02-2004, 08:28 PM
Roadkill Roadkill is offline
Send a message via Yahoo to Roadkill
Does the transmission still work ok? If it ain't broke don't fix it. Some times you may find a small amout of metal shavings in the filter. Its just doing its job. Its better than letting them get back up into the works and really screw something up. When you have metal gears moving against each other and especially if the fluid and filter are long over due for a change, you can find some metal shavings occasionally. If its a few, I would not worry too much. If its alot, then obviously be more concerned. How much did you find?
1997 Saturn SL2-codes and what they mean emmaandleesmom SC/SL/SW 9 10-02-2009 11:53 AM
A/C problem in a 97 SL2. Chad of Metal SC/SL/SW 4 05-24-2009 03:08 AM
92 SL2 tranny into 94 SC2 myrainmann SC/SL/SW 2 04-13-2009 12:11 AM
Engine replacement '96 SL2 dno36 SC/SL/SW 18 12-09-2004 01:02 AM
replacing trans range sensor smitty2 Sable 1 05-15-2004 12:07 PM
