Old 01-01-2004, 08:29 AM
de0147 de0147 is offline
Send a message via AIM to de0147
Intake Manifold
Just found out that my Tahoe, 98, with 77.0 miles has a intake manifold leak. I have been smelling antifreeze. My neighbor who has a 98 Tahoe also, had a cracked manifold in the past month, he has 98.0 miles on his. Is this a problem with all Tahoes? and if so, why isn't Chevy taking care of it. Who do you report it to? He phoned GM and got the brush off.
Old 01-01-2004, 08:49 AM
99ssconv 99ssconv is offline
did you buy the extended warranty, thats what they are for. all gaskets fail over time, however, gm just came out with a new design lower intake gasket for your truck, i installed one yesterday and believe it will help the concern.
Old 01-02-2004, 09:59 AM
Ketch Ketch is offline
Re: Intake Manifold
I just put in a new FEL gasket to fix manifold leak on 99 Suburban 5.7L R engine - probably same as the Tahoe's. How is the "new design" gasket different from old? Perhaps if you posted a picture of the new gasket, all of us who have fought this battle could appreciate if this is worth pursuing.
Old 01-02-2004, 10:12 PM
Re: Intake Manifold
the new design gasket has metal around the bolt holes to prevent overtightening the gasket and causing premature failure.
Old 01-19-2004, 07:39 PM
Re: Intake Manifold
Are we saying that extended warranties should be purchase to compensate for poor design or workmanship. I don't agree. I also don't agree that all gaskets fail over time, unless you are talking about a lot of time, not 77.0 miles. If it isn't a design problem then why the new gasket?
Old 01-19-2004, 09:04 PM
if a gasket could be designed that would never fail then we wouldn't be able to afford the initial cost of the vehicle, the new gasket is a improvement over the original and will also fail over time.
Old 01-19-2004, 09:44 PM
Rick246 Rick246 is offline
I just found out today that my 99 Tahoe has a leak at the intake manifold, I was smelling antifreeze. My mechanic told me that Chevy uses plastic gaskets with a rubber inlay. He believes this is a design flaw. Let me know if there is a better gasket to get. My Tahoe only has 69,000 miles on it.
Old 01-23-2004, 06:44 PM
ronkh ronkh is offline
Send a message via AIM to ronkh
Re: Intake Manifold
I have had 5 gaskets. Yes, it's a known problem. More like alum. mainfold, and different block. Intake manifold gasket should NOT fail, unless it is defective, or put in incorrectly. So it is a design flaw. and chevy should eat it. but they will deny any problems.
Old 01-24-2004, 07:52 AM
sa200 sa200 is offline
Re: Intake Manifold
aluminum expands and contracts a lot more than cast iron..the old motors with cast iron intakes didnt have gasket probs like the new motors...
Old 01-31-2004, 11:18 PM
bumsinflt bumsinflt is offline
Angry
Have 99 Tahoe 70.0 miles - same problem - have a lifter also that clicks when cold - wonder if the two are connected?
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 05:22 PM
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
Aftermarket intake manifold vs. Ported intake manifold Ziggymidget5 Engineering/ Technical 6 06-26-2004 02:27 AM
