Old 01-01-2004, 07:38 AM
W-44Olds W-44Olds is offline
turbo manifolds?
How do the 1st gen 4g63 manifolds differ between the auto and the stick? I know the motors in automatics get the smaller turbo,cams and injectors.I just want to know why the manifolds are different is it the mounting holes for the turbo or O2 housing or what? I need a guru to answer this for me. I really don't know if they are or not but I was told they were. Thanks!
Old 01-01-2004, 08:52 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
yes they are different, the manifold is smaller in the automatic cause they have a smaller turbo --- the opening on the compresser housing is smaller
Old 01-01-2004, 04:22 PM
Thankyou for the reply.My brother has a manifold from his awd tsi 5 speed.I guess he upgraded to a 2nd gen manifold.Hmm maybe I should hit him up for his manifold and 14b.Thanks again.
Old 01-01-2004, 10:06 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: turbo manifolds?
Just a minor correction, its the turbine housing inlet that is smaller.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-01-2004, 10:33 PM
EclipseRST's Avatar
Banned
my bad, thats what i ment but it was early and i was hungover!
Old 01-04-2004, 05:17 AM
2000WJ 2000WJ is offline
Send a message via AIM to 2000WJ
a friend of mine dropped his cracked 1g manifold off at my house today for welding and porting. I fixed the cracks, and started to port it. There are tons of casting flaws!!!!!!!! I'm sure you could find a lot of power right here in the manifold. There's a casting "step" in the outlet which bolts to the compressor housing, the port openings don't match, and there are casting tabs inside the runners. The 02 housing isn't as bad, but it has a quite abrupt 90 deg. angle. Check out 2g manifolds which may be better (?) and EVO manifolds; which also may be better, but I haven't seen them first hand.
B series turbo manifold? 13secondcivic '71-'87 Civic | CRX 11 04-29-2006 02:17 PM
88 rx7 anniversary, new turbo manifold, or new turbo kit? ghostrx7 RX-7 6 04-09-2005 08:19 PM
turbo manifold for 5sfe?? pvang31019 Celica 4 10-14-2004 10:15 PM
Selling turbo manifold, turbo, all plumbing, etc Grendel 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 3 09-04-2002 08:41 AM
Turbo Manifolds cybercrx00 Forced Induction 9 01-04-2002 01:33 AM
