Old 12-31-2003, 06:35 PM
97dsmeclipse's Avatar
97dsmeclipse 97dsmeclipse is offline
Send a message via AIM to 97dsmeclipse
question about rods and pistons
ok i have a 97 gs-t so i has the 7 bolt in it, and im bying some pistons and rods off a frind that has a 6 bolt 99 gsx
and my question is will je piston and eagle rods fit from a 6-bolt fit a 7-bolt
Bottles are for babies - Real men get blown!!!
Car pics
97 eclipse rs - Sold
99 eclipse gs - Blown Motor
97 eclipse gs-t - For Sale
98-99 eclipse gs-x - - Looking for one
Old 12-31-2003, 06:52 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: question about rods and pistons
um there are only 6 & 7 bolt i have never heard anything of a 9 bolt if im wrong please give me info
Old 12-31-2003, 07:02 PM
Re: Re: question about rods and pistons
sorry fixed it, hit wrong button its a 6 bolt
Car pics
Old 01-01-2004, 10:27 PM
kjewer1 kjewer1 is offline
AF - Advisor
Nope, you would need a 6 bolt block/crank. If you are going to the trouble of swapping rods and pistons anyway, why not spend a couple hundred on a used 6 bolt block/crank and do the full conversion and be done with it. The same machine work will be required in either case, etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-02-2004, 12:35 AM
yea im going to go to a 6-bolt here soon, just waiting on the money
there is a local gunkyard with a 99 gs-t 6-bolt for sale with like 13,000 miles on it. Im think about just getting what i need for a 6-bolt swap and doing it that way.
Car pics
Old 01-02-2004, 12:39 AM
AF - Advisor
Just to be sure you understand, 6 bolt motors only came in the 90-92 cars. Anda few very late 92s have 7 bolts. From then on every 4g63 was a 7 bolt. See www.vfaq.com for how to tell them apart by the oil pan if you come across some 1Gs in the junkyard.
Kevin Jewer
Old 01-02-2004, 03:11 AM
ok so maybe im wrong, but i thought 98-99 had 6-bolts, and thats why they didnt get crankwalk
Car pics
Old 01-02-2004, 03:35 AM
AF - Advisor
Nope, but there was a thrust bearing design change in mid 1997 (98 model year) that may be the contributing factor to the 98-99s seeming less prone to crankwalk.
Kevin Jewer
Old 01-02-2004, 09:05 PM
ok should i go with the 6-bolt or just a 99 7-bolt with 13,000 miles on it?
Car pics
Old 01-03-2004, 07:47 AM
AF - Advisor
The 99 is too young to say wether or not it will get crankwalk, but the odds are very very slim. If the 99 is priced reasonably, I would go that route unless you plan to make over 400-450 whp.
Kevin Jewer
Old 01-03-2004, 07:58 AM
Re: Re: Re: question about rods and pistons
ok so im just going to put the 6-bolt block in, what else do i need to make it a 6-bolt. It come with rods and pistons, and i know i need the crank, but what else do i need?
Car pics
Old 01-04-2004, 02:23 AM
AF - Advisor
Everything one would need to do the 6 bolt conversion can be found at www.magnusmotorsports.com under the tech article section.
Kevin Jewer
h22a rods and pistons 93/01alaLUDE Prelude 5 11-21-2004 03:04 PM
need advice on rods and pistons SlowerCivic JDM Motor & Parts info/chat 0 08-20-2004 03:26 PM
rods and pistons? SlowerCivic Let's get Technical! 3 08-05-2004 01:24 PM
rods and pistons question for b20 YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 12-30-2003 12:16 PM
Rods And Pistons civicphrenzy Engineering/ Technical 10 07-25-2003 05:23 PM
