Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-21-2004, 09:28 AM
SlowerCivic SlowerCivic is offline
rods and pistons?
Is it hard to put rods and pistons in?cause i want to get a set of eagle rods for my b18c1 and forged pistons.and around how much boost can I run with those in there or does that make a bid difference?
157 second quarter mile.
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 08-05-2004, 04:10 AM
Dankster18 Dankster18 is offline
Send a message via AIM to Dankster18
Re: rods and pistons?
well im not exactly sure as to how much boost you could run with new rods and pistons but to answer your question putting in rods and pistons is fairly difficult. its best that you have a machine shop do the work cuz if you get aftermarket pistons its may be a lil bigger than the cylinder so you'll need to get it bored to fit the cylinder. and you need to a lil more top end work to run hi boost cuz not only do you need rods and pistons but you'll need valves springs retainers hi boost gaskets and reinforce the deck i hope this helps you some
Old 08-05-2004, 08:04 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
to put rods and pistons in it basically requires a full engine tear-down. plus as he said you will need a machine shop to hone the cylinder walls to seat your new piston rings, or else you will get alot of blowby.
as far as boost goes, make sure you get low compression pistons or the amount of dyno&tune time will not justify the gains in power.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-05-2004, 01:24 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Use the Haynes or helms manual as a guide. If you dont have one, then go get one.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
