Old 12-31-2003, 02:13 PM
tom coon tom coon is offline
Question suburban rear window
the rear window on my 86 suburban has frozen. The window is now open and won't go up. I can't access the motor to replace it without removing the window. How do I do that?
Old 01-02-2004, 03:38 PM
toivo toivo is offline
Re: suburban rear window
you will have to remove the acess panel to the reardoor and have someone push the up button while you lift on the window. also check electrical connections while your in there and make sure your control button is delivering power.
Old 01-11-2004, 08:38 PM
thanks for the info, I was able to do that and spot what I think was a short in the wiring. So far, so good..
Old 02-21-2004, 06:18 PM
spruce spruce is offline
Re: Re: suburban rear window
How did you get the door panel off?
Old 02-27-2004, 11:16 AM
Isaac123 Isaac123 is offline
Talking Re: Re: suburban rear window
Toivo:
Have a 97 Diesel burb with the left rear cargo door not opening. Could the be a contact problem, or do I have to take the door panel off to unlatch? Can the lock mechanism on the right rear door be worked on (this door opens) instead?
Thanks in advance.
Radio problems/ Rt rear window won't move/ Lights dim when shifted in Reverse Baxoid Grand Prix 2 01-03-2010 06:50 PM
2000 Accord Rear Window Malfunction pumatiger Accord/TSX/Accord Hybrid 1 08-03-2009 11:56 PM
1999 Suburban rear windows stuck Pat111 Suburban 0 10-14-2006 03:20 AM
1988 Suburban - Rear Window won't close Mdguy_20878 Suburban 3 03-21-2005 12:42 PM
1990 Suburban rear window (and defog) question Hoyt Suburban 0 12-13-2004 11:42 AM
