Old 12-30-2003, 05:38 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Question Can anyone post a pic of where the wire harness for there MAP goes?
It looks like my map sensor is on the firewall, but my throttle body has a spot exactly for it. I posted pics about that earlier here's one...the hose that's on there goes over to a little black box attached to the firewall
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 12-30-2003, 08:06 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Can anyone post a pic of where the wire harness for there MAP goes?
all the 88-91 go to the same spot, look under that black cover and you will see the map sensor and the harness. 92+ has the map on the TB, so their harness is different.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-30-2003, 08:12 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: Re: Can anyone post a pic of where the wire harness for there MAP goes?
the harness is not different. if you get a 92 civic map sensor the harness will plug right into it, all you might need to do is extend the wires a lil bit.
heres a pic of my engine when stock and you can see the stuff on the firewall and then a pic after my swap where its now attached to the TB.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 12-30-2003, 08:40 PM
EF You's Avatar
EF Life Giver
Re: Re: Re: Can anyone post a pic of where the wire harness for there MAP goes?
[quote=GTA]the harness is not different. if you get a 92 civic map sensor the harness will plug right into it, all you might need to do is extend the wires a lil bit.
QUOTE]
thus, the harness is different. i know that the plug is the same type, but the wires are too short.
Old 12-30-2003, 08:48 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: Re: Re: Re: Can anyone post a pic of where the wire harness for there MAP goes?
well i didnt have to extend my wires, but if you leave the purge solinoid (the other thing the harness goes to) on the firewall you will have to.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 12-30-2003, 11:46 PM
quiXilver's Avatar
Well this is what I bought...
But see this connection? I don't see the other end to it anywhere...
Looks like to would fit right where that hose it connected on top of the throttle body...
omg...I think it just finnaly clicked...the wire harness is under the black box on my fire wall isn't it???
B18A
Old 12-31-2003, 12:37 AM
EF You's Avatar
EF Life Giver
umm, yep, its under that black box
Old 12-31-2003, 01:14 AM
quiXilver's Avatar
So the connector that is under the black box that is already connected to my current map will fit this new one?
B18A
Old 12-31-2003, 02:59 AM
GTA's Avatar
GTA GTA is offline
Whee..
yes it will fit the new one.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 12-31-2003, 03:14 AM
91civicDXdude's Avatar
ah must be an 88 with the famous BOX surrounding the map instead of the small firewall assembly on every other year
Can anyone tell me where the fuel filter is? tybeho Econoline 4 10-03-2007 08:23 PM
Can anyone tell me where the Reverse light switch is Shootist Cherokee 3 04-23-2005 08:32 PM
Does anyone know where i can see a pic of the fuse chart fot the civic?? DJHyperXK2004 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 08-12-2004 02:09 PM
Where can i buy a 2000 integra complete engine wire harness for cheap Amped_phx Integra 1 01-30-2004 09:28 PM
can anyone post there pogress pics of there body kit eclipse52 Car Modeling 7 06-05-2003 02:12 AM
