Old 12-30-2003, 01:39 PM
RochelleC RochelleC is offline
Question Fuel Gauge does not work
My fuel gauge does not work - shows empty when it is not. Is there a way to fix this?
'91 S-10 blazer regular, not a 4wheel drive
Old 12-30-2003, 04:13 PM
GMCMAN GMCMAN is offline
Re: Fuel Gauge does not work
Check Your Fuses If They Are Good Then Chances Are The Sending Unit Is Shot,its Not A Expensive Fix If That Helps Ya Any Also You Can Pull Your Dash And Check The Connections To It Good Luck Gmcman
Old 12-30-2003, 05:51 PM
What is 'Sending Unit" and where is it located?
Rochelle
Old 12-30-2003, 11:45 PM
joshzr2 joshzr2 is offline
The sending unit is what tells your fuel gauge how much fuel you have and should be located somewhere around the tank. Your fuel gauge showing empty could also be what causes your check gauges light to come on. If both problems are on the same vehicle, they could possibly be related. Not sure though, just a guess.
Old 12-31-2003, 08:23 AM
Thank you
rochelle
Old 02-21-2004, 03:50 PM
Just thought I would add my latest information. All of a sudden........it is working again. Don't know what happened - but now my tank shows full when full the needles moves accordingly
Old 04-06-2004, 05:24 PM
tyler62601 tyler62601 is offline
Send a message via AIM to tyler62601
i think there might be a short in the wiring somewhere mine did the same thing but the connector was loose.
2000 Sportage Fuel Gauge Not Working...HELP!! hottmpr80 Sportage 1 08-03-2010 08:35 AM
I have a 2000 Crown Vic Police car gas Gauge does not work clark4017 Crown Victoria 1 12-09-2008 12:54 PM
Help gas gauge does not work right and is not taking gas well!!! spflick Taurus | Taurus Wagon 9 08-05-2007 02:21 PM
1996 gas gauge does not work ejsegur Riviera 8 03-19-2006 11:21 PM
mk2 gas gauge does not work. Plese help! mr2nr MR2/MR-S 1 12-21-2003 11:51 PM
