Old 12-30-2003, 12:34 PM
ofcmlong ofcmlong is offline
Send a message via Yahoo to ofcmlong
Exclamation 96 Blazer Problems
I have a 1996 Blazer 4d 4wd 4.3L. The problems started with the service engine soon light. Then it was hard starting. The hard starting kind of went away. The service engine soon light went out and doesn't come on at all not even at start up. It takes two tries to get it started. The first time it starts and then immediately shuts off. The second time it starts right up and is fine. Performance doesn't seem to be hindered. The last problems is that when I filled it up gas ran out. I waited til the pump went off went to put the nozzle up and gas ran out from the rear.
Any suggestions?
Old 12-31-2003, 07:25 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 96 Blazer Problems
If the SES light does not come on during the bulb check (key in the run position) I would check the fuses that power the PCM....This may be an indication of a loose connection or that the ignition switch is not sending current to the fuses
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-31-2003, 11:44 PM
Well I found out what it was. I took it to the dealer I bought it from and they pulled the gas tank thinking a seal was broken around the fuel pump. Apparently they found the gas tank was weak on the top side and had a couple holes in it which gave me the service engine soon light and problems starting.
A new tank was ordered it will be fixed in a couple of day free.
1996 S-10 Blazer DTC Problem (P1192) arthurjohn Problem Diagnosis 17 02-16-2010 08:09 PM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 11:45 AM
98 s10 blazer problem Reep19 Blazer 4 12-03-2003 09:31 PM
2000 blazer problem abbey516 Blazer 0 11-27-2003 09:50 PM
Blazer problems ExtremeBoy44 Street Racing 0 10-31-2003 11:58 AM
