Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 12-29-2003, 09:43 PM
lpho lpho is offline
Unhappy Can't go forward...only in reverse
All of a sudden my car no longer moves forward. It will go in reverse. I had to leave it on the side of the road. Any ideas of what might be wrong? Thanks.
Old 02-18-2004, 05:21 PM
JP_GD2004 JP_GD2004 is offline
Re: Can't go forward...only in reverse
Put it in drive. Just kidding!
I would guess transmission. Was it "slipping" at all prior to this?
Old 02-20-2004, 08:31 AM
amac209 amac209 is offline
Send a message via MSN to amac209
check the fluid level in the tranny first, do this wile idling in park. i'd say you probably broke a band in the tranny and need a rebuild. i'm sorry
Old 02-20-2004, 08:37 AM
MethodMan420's Avatar
MethodMan420 MethodMan420 is offline
yeah I have had this happen to my first car. My reverse went out, I drove it that way for over a month... never realized what a pain in the ass it is to find a parking spot that you dont have to back out of.I had no chance of ever pushing it out of a spot it being a Chevy Caprice
Old 02-20-2004, 09:01 AM
ha you should've cut a hole in the floor and went flintstone style
Old 02-22-2004, 11:40 PM
Stephen B Stephen B is offline
The cause of your problems may be as simple as low or no fluid. Next check to see if the linkage is working properly. If all external checks are OK then the most likely cause is the front clutch assembly may have failed but you should have noticed engine flaring and slipping before hand.
Bands in a Chrysler transmission are only applied in reverse so this wouldn't be the problem.
Good Luck.
Old 02-23-2004, 09:23 PM
ironman502 ironman502 is offline
Good Luck.
Are you sure about the bands? We have a '96 Caravan 3.0 liter 3-speed that has a bad main axle seal, so it leaks tranny fluid badly. Once, the fluid got too low and the transmission started slipping terribly in the forward gears, even when full of fluid. We tightened the bands about 1/4 turn and now it works much better, though it shifts a little rougher.
'85 BMW 325e
'87 Shelby Lancer #340
'00 Dodge Neon
Therefore, having been justified by faith, we have peace with God through our Lord Jesus Christ. (Rom. 5:1)
94 Jetta only Goes Forward in Reverse Ricanken '91 - '96 0 10-28-2010 01:32 PM
'92 Lumina 3.1 No forward only reverse Don B Lumina 6 11-05-2006 02:10 PM
No drive forward or reverse riliffe Galant 2 04-17-2005 09:27 PM
Forward in reverse.. very bad? Vtec95Civic Let's get Technical! 9 01-03-2005 06:17 PM
No forward or reverse dav1738 Contour 3 11-06-2004 10:58 AM
