Old 12-29-2003, 08:29 PM
95gts98gt 95gts98gt is offline
Send a message via AIM to 95gts98gt
95GT problems after a tune -up
my friends 95 Gt has 80,000 miles on it he just got a tune up and the only modifications done to it were air box was removed timing adjusted to 14 and a K&N filter and the check engine light comes on any suggestions
95 GTS...9mm FRPP spark plug wires, BONE STOCK
Old 12-29-2003, 09:05 PM
eillob's Avatar
eillob eillob is offline
It might be a good idea to disconnect the negative terminal from the battery to let the computer reset itself. This takes about 10 to 15 minutes to clear and then reconnect. Anytime you do a major tune up especially if it involves timing or you change the rate that air comes into the car it has a tendancy to confuse the computer. And the first thing it does is give you check engine lights. I don't know how many times I've gone round and round with this car for that same reason. After you reconnect put it on the road and drive it for about 15 minutes, this will give the computer time to adapt to the new information its recieving.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 12-30-2003, 09:08 AM
Mendari Mendari is offline
Check the wiring to the Mass Air Meter. If it became disconnected or damaged, that will send a signal to the check engine light. Also, try reseting the computer as mentioned by eillob. If that doesn't work, push back the timing to the factory 10* and reset the computer again.
Old 12-30-2003, 11:09 AM
Re: 95GT problems after a tune -up
i just looked under the hood and couldnt find anything wrong,,but i started it up let it idle for about 2min then drove it and everything was fine
Old 01-01-2004, 07:12 AM
parrish5o's Avatar
parrish5o parrish5o is offline
I know guys that have driven around for years with the check engine light on. The only time mine has came on 02 sensors fixed it.
CANFIELD STAGEII HEADS SCORPION 1.6 COMP CAM 555/570
GT40 INTAKE STAGEII LOWER 65MM TB PRO-M 75MM MAF
30LB INJECTORS 190LPH FUEL PUMP/ NOS INLINE PUMP
FMS ZT5 CENTERFORCE CLUTCH HURST SHIFTER
ALUM DRIVESHAFT 31SPLINE MOSER AXELS AUBURN DIFF
ALUM RADIATOR MSD 6AL MSD ADJUSTABLE TIMING RETARD
NOS STAGE II 150HP 497@5800 474@4300 11.3@118
Old 01-02-2004, 01:17 AM
vbrpete vbrpete is offline
Remove the K&N and filter box.Check the filaments on the mass-air meter.See if they're covered in oil(from the K&N).This happens a ridiculous number of times at my shop;people put in a K&N expecting a HUGE hp increase,and end up with a Check Engine light and reduced performance.Turns out that any excess oil in the filter gets to coat the MAF filaments,insulating them and eliminating their signal transmission to the EEC.Clean it off with some thinner and a Q-tip and the problem should go away.If it doesn't,then look elsewhere,but the filter should be your first concern here.
Old 01-02-2004, 04:15 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Good advice vbrpete, but I really wouldn't use thinner. I would use either rubbing alcohol or electronic parts cleaner. Also be VERY careful not to damage the filaments, because there are extremely delicate.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-02-2004, 09:06 AM
ill show this to him thank-you
94 deville after tune up starting problems ... please help vking76 Deville 10 03-12-2008 05:51 AM
Idle problems after tune-up. StarWrist Eclipse Problem Diagnosis 3 01-18-2007 05:46 PM
95 after tune-up, misfiring again cubanlorenzo Blazer 10 02-24-2005 02:04 PM
slight miss after tune up? slreno1217 C/K 6 02-18-2005 11:45 PM
Car Trouble RIGHT after tune up nirm2 Accord/TSX/Accord Hybrid 2 09-07-2003 05:00 PM
