Old 12-29-2003, 07:11 PM
Hombre Dinamita Hombre Dinamita is offline
94 vibrates when in drive
When it is in drive it vibrates alot. When in Park or Neutral it doesnt.
It drives fine, it just vibrates alot when you come to a stop. Could this be an engine mount? What else could it be? Any help will be appreciated.
Old 01-07-2004, 01:32 AM
tigerland tigerland is offline
I had a similar problem with my 93 LX, and I found the problem to be a loose bracket on the exhaust pipe. Let me explain. On the underside of the car, on the exhaust pipe, there is a bracket that connects to the oil pan. The screw that held the bracket to the oil pan must have vibrated loose and came out. I noticed this when I crawled under there to change the oil. Anyway, that pipe was really banging around and caused alot of vibration when the car was at idle. I put another screw in and it made a big difference, especially at idle. Maybe you could check that bracket. The bracket connects to the side of the oil pan and can be easily seen when your under the car. Hope this helps.
Old 01-07-2004, 12:34 PM
Thanks. It was what I suspected, it was a transmission mount that was tore up.
Vibration when driving straight djvsmarkviii Trans Sport 4 03-06-2010 03:11 PM
Front end vibration when driving. jrrtex99 Explorer | Explorer Sport Trac 6 01-15-2010 08:00 AM
Vibrations when driving IZ1111 Crown Victoria 2 12-30-2007 02:35 PM
Vibration/Noise when driving at normal speeds Navigator46 Accord/TSX/Accord Hybrid 7 06-17-2004 10:58 AM
96 GC Vibrates when driving WhiteGC Caravan | Voyager 2 01-22-2004 11:28 AM
