Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-22-2009, 09:14 AM
jrrtex99 jrrtex99 is offline
Front end vibration when driving.
Good morning all, I have a 2000 Eddie Bauer AWD (5.0) with a front end hum (high frequency vibration) that occurs at all speeds. Brakes are ok, tires have been rotated/balanced. The only time it seems to go away is when going into a right hand curve at highway speeds, as soon as i straighten out, it comes back. Any insight would be helpful so I'm not taken to the cleaners when I have it repaired.
Thanks!
Old 12-22-2009, 02:01 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Front end vibration when driving.
Is it related to vehicle speed, such that the faster you go the higher the frequency?
Sounds like you probably have a right front or right rear wheel bearing going out.
-Rod
Old 12-22-2009, 02:26 PM
Yes, it starts about 20 mph as a lower frequency growl almost, and then it increases in frequency as speed increases. If it is a wheel bearing, how big of a job is it?
Old 12-29-2009, 12:20 AM
FYI: It was the front drivers side wheel hub assembly. $300 to repair, not too bad.
Old 12-29-2009, 06:07 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Thanks for taking the time to post the fix. We really appreciate the time you took to let us know what the fix was. Good luck and Happy New Year.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-15-2010, 07:15 AM
patapen patapen is offline
wheel hub as in wheel bearing??
Old 01-15-2010, 08:00 AM
yes, i believe the whole thing is an assembly. Just make sure that the shop puts ALL the bolts in the brake caliper, which this one failed to do...
