Old 12-29-2003, 03:44 PM
marjhan marjhan is offline
Can inverter short radio? Fuse still good, now what?
Had an inverter plugged into cigarette lighter and was powering a laptop when one of the leads came off the inverter and touched the other one (I think). The radio went dead as did the lighter. I checked the fuse box by my feet and the radio fuse still looked good. Thoughts on where to look next please? Is there an in-line fuse on this stock CD/radio player? '97 Honda Accord SE.
Old 12-30-2003, 10:28 PM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
check your accessory fuses both underhood and in the cockpit.If neither the lighter nor the radio works also check radio fuse underhood i'm pretty sure your year has one a 7.5a i think. You might want to think about hardwiring that bitch so you don't draw the current through the lighter plus you could put it on a switch.
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
Old 12-31-2003, 11:00 AM
Re: Can inverter short radio? Fuse still good, now what?
I pulled the 15amp fuse from the engine area and dropped it before I had a chance to check it, but when I plugged a new one in there, shazam! it worked! Thanks for your help!
95 Jeep Grand Cherokee Radio Fuse Keeps Blowing - Dead Battery ajcool Grand Cherokee | Grand Cherokee SRT8 1 04-25-2010 10:30 PM
New ignition cylinder, security light still on, now what?? ff_sssmokin Impala | Impala SS 6 11-30-2009 01:35 PM
Radio fuse shorting ruzzier Cavalier 0 12-14-2005 09:46 AM
Wipers wont work?? fuse still good!? JGTP94 Grand Prix 12 01-13-2004 01:05 PM
Short Shifter help, whats good and what is involved ex2fast4u '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 04-16-2002 11:30 PM
