Old 12-26-2003, 07:57 PM
JGTP94 JGTP94 is offline
Send a message via AIM to JGTP94
Wipers wont work?? fuse still good!?
ok i have a 94 GTP and today when i tried to use my wipers they did nothing then a little later i tried it again and it worked but now they are not working at all and i cant figure out the problem is!!! Does anyone have any ideas what this could be??? any input helps
-Thanks-
Old 12-26-2003, 10:06 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
is it snowing where u are??
Could be snow or ice related
Old 12-27-2003, 12:09 AM
carnutcass's Avatar
carnutcass carnutcass is offline
Can you hear the wiper motor running? Have you checked the jam nuts at the base of the wiper arms. They're desinged to loosen themselves in the event the wipers get hung up.....ie: ice, obstruction, crud, whatever.
Old 12-27-2003, 12:26 AM
Re: Wipers wont work?? fuse still good!?
there is snow here but i hear no motor and they did it even after the car was in the garage for over an hour. I am deffinatly confused on this one... i hope someone thinks of somethin cuz i dont want to waist my money on somthing stupid
Old 12-27-2003, 01:35 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Well once happened to me that the switch was not working properly and if I jiggled and hold it in a certain position it worked. If the fuse is ok and no motor sound you hear then "wiggle it, just a little bit" the switch to see what happens
Old 12-27-2003, 10:19 AM
well i just tryed wiggling it for like 5 mins while i was tring to get them to work, maybe it is a loose wire or something but i have no clue where the wiring for the wipers is so i dunno
Old 12-27-2003, 03:28 PM
kilroypr's Avatar
OK to me look like the switch is the trouble. The side marker is a module that includes the hazard as well. to get to the cable you must take off the sterringwheel column top and lower covers.
If you are going to do this buy the switch first it is not that expensive
Old 01-09-2004, 11:16 PM
bluerz bluerz is offline
dont replace the motor I just fixed this one try removing the plasticgard from the wiper motor asslemby and strip a wire at one end and place it on some metle of the assembly then take teh other end and ground it to the car and see if that works
Old 01-12-2004, 11:24 AM
fast98gtp's Avatar
fast98gtp fast98gtp is offline
Send a message via AIM to fast98gtp
kilroypr is right about the switch. my girlfriend has a 2000 gp and her wipers quit working properly. most of the time we had to pull the fuse just to make them stop. the variable speed didnt work either. we took it to the dealer and they said that it was the multifunction switch(controls wipers, turn signals, cruise, hazard lights). from the dealer it will cost over 400$ to have it installed. but i ordered one from autozone for 228$ and it got there by lunchtime the next day. just the other day i put it in. it's expensive but that's probably what will have to be done. her wipers work perfectly now.
Old 01-12-2004, 11:26 AM
fast98gtp's Avatar
kilroypr is right about the switch. my girlfriend has a 2000 gp and her wipers quit working properly. most of the time we had to pull the fuse just to make them stop. the variable speed didnt work either. we took it to the dealer and they said that it was the multifunction switch(controls wipers, turn signals, cruise, hazard lights). but then it may be different for your car. but for the 97up models, from the dealer it will cost over 400$ to have it installed. but i ordered one from autozone for 228$ and it got there by lunchtime the next day. just the other day i put it in. it's expensive but that's probably what will have to be done. her wipers work perfectly now.
Old 01-12-2004, 11:27 AM
fast98gtp's Avatar
^^sorry about the dual posts...i thought it froze up on me so i posted again
Old 01-12-2004, 11:31 AM
fast98gtp's Avatar
if you are going to have to do that to your car, be VERY careful with the airbag if you have to remove it. I dont know how older gps are but the 97 up ones have to have the airbag taken out of the wheel. by far the best instructions for doing anything like that would be in a Chiltons book....get one...it will tell you everything
Old 01-13-2004, 01:05 PM
i just replaced switch and if fixed the problem not too hard air bag is in the way but im all dont and now i can see when it rains
Thanks!
99 Ford Taurus Wipers wont work fletch0098 Taurus | Taurus Wagon 6 03-27-2006 04:20 PM
92 Taurus wipers wont work alfthree Taurus | Taurus Wagon 1 08-21-2005 01:17 PM
Windshield wipers wont work..... DisneyVK Neon | Plymouth Neon 2 09-08-2004 08:05 PM
2 Noises too many + windshield wipers wont work + CD Error! PLEASE HELP Hamidxa Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 02-19-2004 10:04 AM
Can inverter short radio? Fuse still good, now what? marjhan Car Audio 2 12-31-2003 11:00 AM
