Old 12-29-2003, 01:20 PM
freddyrod freddyrod is offline
Question 92 Voyager 3.0 Cranks but not start.
Hi,
I have a 1992 Plymouth Voyager, 3.0 engine, 3 speed that will not start. Initially engine went dead while waiting at a drive-thru, idling in drive. It turns over fine, but does not catch on. Things that I have checked:
1. Spark out of Ignition – there.
2. Distributor rotor move when engine is cranked.
3. Spark plugs looked dry.
4. Checked fuel pump output rather coarsely, disconnected fuel supply hose from injector assembly and into a can. Cranked engine and notice fuel shooting out.
Well I have air, fuel and spark. Why wont it start??
Not really familiar with all the relays and sensors that could contribute to problem. Please if you have any ideas as to what it could be, email me as soon as you can. I really need to get this going.
Thanks ahead of time.
Old 01-15-2004, 11:28 AM
PhilG PhilG is offline
Re: 92 Voyager 3.0 Cranks but not start.
I am experiencing very similar problem . .did you ever get a resolution and get it started?
Phil
Originally Posted by freddyrod
Hi,
Old 02-05-2004, 01:21 AM
glemieux glemieux is offline
turn the ignition key on and off quickly 4 times,the 4th time leaving it on,and see if you are getting any trouble codes through the check engine light,if not...check for a clogged cat converter
Old 02-09-2004, 09:38 PM
Tom Cat Tom Cat is offline
I fixed a plymouth car with a 3.0 engine. This engine is a mitz 6G72. I work for a Cat/Mitz lift truck dealer and we have the same engine in some of our larger lift trucks. Anyway the car would turn over and would not start. I checked spark, air, and Fuel. I had fuel coming out when cranking. I pulled the fuel pump out of the tank, and it had been replaced a few months later, but it was not put in correctly and it was full of junk. I put a new fuel pump in the tank, correctly this time, and it started first time. Even though you are getting fuel, it may not be enough. The fuel pump would be a place to start.
Old 04-17-2004, 07:17 PM
woscarr woscarr is offline
Funny thing...
Let me tell you a story.
Yesterday, I just pulled into the wendy's drive thru and the engine on my 92 plymouth voyager stalled. Hmmm strange, never did that before.
Well I tried to crank her... No go, had to push her out of the drive thru lane.
Ok what's wrong. She's cranking, I hear the fuel pump coming on. The cranking sounds kinda funny. I get my flashlight take off the oil filler cap, shine my flash light in and press the button on my auto start...
Sure enough... she's cranking but the valves are doing nothing
Broken Timimg Belt !
Well today after getting a recker to pick her up, I got the whole front of the engine stripped off and is in the process of replacing the timing belt. Im actually stuck at the fly wheel bolt, I can't get it off (anyone care to help me!), I can't find anyway to jam the flywheel in order to get the nut off.
So hopefully your luck ain't as bad as mine.
Wayne
Old 04-23-2004, 07:03 AM
slantsixness's Avatar
slantsixness slantsixness is offline
Freddyrod,
throttle position sensor...? try flooring it, if it starts then, may be your trouble.
woscarr,
use an impact, or use the inspection hole in the trans and jam the torque converter, but don't expect it to be easy that way, and watch out for the converter. The impact wrench is best. You can also lock the conveter by removing the inspection plate on the trans, or wrap a belt around the harmonic balancer and twist it tight and it might be enough to hold, then again it might not!
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 04-24-2004, 07:29 PM
Just to add... I got the crank bolt off... thanks.
The distributor dosen't run off the timing belt in the 3.0 Mistibishi motors. It's gear driven off the crank.
So you can't tell if the timing belt is broken by checking the distributor.
Old 11-02-2006, 11:23 PM
JUNO101 JUNO101 is offline
Hi,
Old 11-04-2006, 04:35 PM
ethos_one2000 ethos_one2000 is offline
Originally Posted by JUNO101
does the dash still dispaly the millage?? if not remove the heat controls and there will be a burnt out terminal in the electrical plug fix this and your problems are over
steve
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
2000 eclipse 3.0 cranks but won't start carlosgonlez Eclipse 2000+ 3 09-19-2007 05:11 PM
2000 cherokee cranking but not starting till second crank kevincourious Cherokee 3 06-11-2006 12:08 AM
89 Voyager Cranking but not starting. dallas121469 Caravan | Voyager 0 02-22-2006 04:23 PM
92, 3.0 Cranks but doesn't start freddyrod Caravan | Voyager 3 12-29-2003 11:46 PM
