Old 12-29-2003, 12:24 PM
hondahead420 hondahead420 is offline
Send a message via MSN to hondahead420
Angry help dx to si problems revs bounce at idle
i have a 90civic hb swapped a d16z6 head on it. car runs and drives up to 3500 rpm then cuts out. vtec is not hooked up yet.at idle it revs to 1500 and then drops to 500 then back to 1500....i have checked for vaccum leaks and can not find any. i am runnin a 90 si comp,94 ex intake,94 ex distro this car is confusing several master techs? if you have done this swap please respond!! i have to work at five
Old 01-30-2004, 03:04 PM
jeremy172 jeremy172 is offline
Re: help dx to si problems revs bounce at idle
my car did that it's your idel air control valve.i think anyway ,there is is this peice that comes loose in there and it lets coolent in well the when it gets loose it lets it in,well the it freaks out and thinks the car is cold so it jacks up the idle and as soon as it does that it all goes out idel goes down and then it does it all over again and again my car did that forever and my buddy told me about it it worked good luck
Old 01-31-2004, 09:39 PM
SupermaN3 SupermaN3 is offline
My Civic was doing the same thing after a rebuild on the Head. It turned out being the Idle Control Valve. Follow the steps in your Maintenance manual to adjust the Idle Control and reset the ECM (ECU). I did and it worked like a charm!!!!! Good Luck.
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
Problems with cold idle rev djstifft Taurus | Taurus Wagon 1 08-21-2005 01:45 PM
bouncing idle rks1428 Accord/TSX/Accord Hybrid 1 09-06-2004 03:30 PM
Bouncing Idle boozybomb '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 08-27-2004 02:17 PM
Bouncing Idle Fix(i Have The Answer) tyler666 Prelude 2 03-30-2004 12:53 PM
