Old 12-29-2003, 04:09 AM
Nig_Row Nig_Row is offline
What two foot flame out my apexi exhaust on a stock gsT?
Well.. Riddle me this automotive forums. On a ride Back for the Street Races in riverside, 2 team members of mine spotted a 2 foot flame shoot out the Exhaust for about 5 sec. while i was hitting roughly 130mph with the pedal to the ground, Now from what i noe the car was stock when i bought it, all i did was install an APEXI N1 Down pipe and the N1 Exhaust system, so its straight 3 in. piping from the turbo, no cat. the car did come with an HKS turbo timer and The HKS evc Boost controller i found after i had purchased the car hidden away under the dash fully installed and wired but both were off. Tell me could there already be a fully bulit engine under my hood!!! or possible 550 or 650 fuel injectors or could it be that the previous own had retarted the timeing so he could boost higher on the stock t25? could this be it? or is there something else. this just happened tonight so i havent had a chance to run a diagnostic, i was hoping for some insight. What do u all think?
Old 12-29-2003, 06:55 AM
kjewer1 kjewer1 is offline
AF - Advisor
You hit the 130 mph speed limiter on the GST
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-29-2003, 12:44 PM
No deal Racer, ive hit 140 in my car before. So its not the speed limiter and its not governered.
Blueprint 4g63
Old 12-29-2003, 01:56 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: What two foot flame out my apexi exhaust on a stock gsT?
my speed limiter is about 140, or 139 or so, but more so, how would that cause a 2 foot flame to kick out the back?
Old 12-29-2003, 02:19 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
The only two 'speed limiters' are some 2g FWD's at 130mph, and a 7500rpm fuel cutoff in any gear including 5th, in essence limiting your speed to whatever that is. I dont know what it is because i havent done the math or gone that fast (id rather not redline 5th gear) All other cars should go as fast as their engines will let them.
I'm thinking the only way to shoot a flame is to have un-burned gas or high enough octane so that even exaust gasses are flamable, inside the exhaust pipe. Top Fuel dragsters have flames because their engines run at too high RPM (too fast) to burn all fuel before it leaves the combustion chamber and exits through the short exhaust pipes, while still aflame. I'm not saying either could be true in your case, I don't know enough about it.
Old 12-29-2003, 06:06 PM
i got a pic of me doing 129 on the site in my sig, and the only reason it wasn't higher was because i was fooling around trying to get the dig cam to take a pic, so i was slowing down, so believe me when i say that my GS-T has a speed limit at about 140. also my girl toy was in the car about to lose her head. this was at night and the funny part was that when the flash went off (without a flash it was all blurry red lines) it blinded us both for a couple of seconds. **warning this is inherently dangerous, don't try this yourself, at night, with a volitile blonde*** but if you still feel as if i am full of it, i will take another pic, at a higher speed, on a closed course, naturaly...
Old 12-29-2003, 06:40 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
I'm I the only that does not look at the Speedo ?
If wasn't for my dyno sheet, I wouldn't of known what my top speed was
They're so much more important things to look at
me=Anti-Speedo
btw I top out at 135mph exact
-Agim
Old 12-29-2003, 09:21 PM
AF - Advisor
The speedometer in the ar is NOT accurate. And the higher the speed, the further off it is. The speed limiter is at 130, so dont fool yourself. Its right in the ECU. The only way around it is to do what the vfaq says to remove it. GSXs do not have this speed limiter.
Whenever you hit fuel cut, wether its the speed limiter or the rev limiter, you can get flames out the back. I get it with my car at the rev limit, and on the stutter box. Its to be expected.
Kevin Jewer
Old 12-30-2003, 03:12 AM
ok ok mabe so, but i think i found the problem. Today in the later evening my car startred sounding as though i had bought a auto zone muffler and duct taped it to a 1989 honda accord. ive seen this by the way and its not pretty.
It was also lagging and miss idleing in neutral why? ,i thought what the fu** happened?.
MASSIVE exhaust leak in the down pipe to turbo connection, my belife is that the gasket was trashed on account of the shop it was installed at was second rate and didnt use a torqe rench to mesaure the bolts, now; when the flame shot, it was fine and dandy no leak, all the sudden. exhaust leak, does this have anything to do with the the flame? is there a direct relationship here or could there be something else?
Please remind ourselves that this post is not here to debate rev limits or governed top end GST/GSX
Old 12-30-2003, 05:34 AM
exhaust leak wont cause flames out the back
flames will be caused from unburnt fuel ending up in the exhaust/running really rich
-Agim
Old 12-31-2003, 04:12 AM
AmericanEagle's Avatar
AmericanEagle AmericanEagle is offline
Send a message via AIM to AmericanEagle
Well i was informed that i shot flames also. I don't know if it happens at high speeds. But when i let off the gas and took a corner a few of my friends said i shot a nice flame. I have never seen this but i'm sure it was not the first time. I have the full exhaust done with a N1 and a few other mods.
1997 Eagle Talon TSI AWD A/T "Never Lift To Shift"
Injen Filter - Forge Motorsport BOV - Magnecor 8mm Race wires - NGK BPR7ES - Apex'i N1 - Joe p MBC - Modified Dejon "L" Pipe
Old 12-31-2003, 02:56 PM
Re: Re: What two foot flame out my apexi exhaust on a stock gsT?
aww, that's it... now i gotta have somebody follow me around so i can see if i shoot flames....
Old 02-01-2004, 02:48 PM
gs-t spyder gs-t spyder is offline
ya they will shot flames its kinda cool, i got 2 buddies that have there cars set up with a coil and a spark plug on the muffler and they have a kill switch to shut the motor off momentary and then they shoot flames out there back all the time its cool i wanted to do it to mine but we figured with the turbo it may not work as well because of that and also they back fire and i dont want any of that with my turbo i just figured not a huge idea but with the right straight threw exhaust the turgo will shoot some flame all on its own
Old 02-02-2004, 07:59 AM
AF - Advisor
I'm nt going to bust your balls about the date of the thread, and you added some decent, on topic info. But that massive run-on sentence just wont do Use some punctuation!
Kevin Jewer
Making your Car shoot flames out of exhaust? Julzboi661 COMPLETELY off-topic 25 08-13-2007 02:04 AM
flames out exhaust? rice(er) Engineering/ Technical 3 09-23-2005 06:33 PM
2000 HX flames out of exhaust sinister2002 Street Racing 19 07-11-2004 11:44 AM
flame out of exhaust pipe Eagle88 General Discussion 7 04-29-2004 06:21 PM
how to shoot flames out my exhaust? 97civiclx '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 12 04-29-2003 07:13 PM
