Old 12-29-2003, 12:20 AM
sweetwhiteCAV sweetwhiteCAV is offline
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
intake question
i want to scratchbuild a cold air intake. but im not sure what to take out from under the hood.
how much of the three peices (three black peices bottom left) should i cut away?
also, if i do cut that out, should i try to put something else there or just leave the empty space?
Old 12-29-2003, 12:26 AM
Kasso's Avatar
Kasso Kasso is offline
Send a message via AIM to Kasso Send a message via MSN to Kasso Send a message via Yahoo to Kasso
Re: intake question
i personally would cut out the 2 right-most pieces. i wouldnt worry about filling it in because the air filter will be there. you can however try to make up the engine bay space if it looks too empty.
1995 Acura Integra Special Edition (something real special about a 5000 rpm changeover... )
Old 12-29-2003, 01:34 AM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Here is what you will need to cut out, and here is where the intake goes, just to let you the cold air intake goes under the car.
Old 12-29-2003, 01:55 AM
Kasso's Avatar
Re: intake question
Not necessarily. i've seen cold air intakes on the same level as the valve cover. actually its much better to keep the filter high up. because, if u dont have a water guard (or whatever its called), water and debris will go into it forcing you to replace it.
Old 12-29-2003, 02:03 AM
=p
Re: Re: intake question
Uh thats called a Short Ram Intake (regular intake) buddy! not cold air.
Old 12-29-2003, 02:06 AM
Kasso's Avatar
Re: Re: Re: intake question
well i didnt mean any offense before. my bad.
Old 12-29-2003, 12:12 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I would cut out all three peices, as they are all resonance boxes for the intake that come stock with the Civic. On the 1:1 they are all one big part, so if you only removed the rightmost parts, it would require you to cut the airbox in half which would just be pointless. Like shorty said, the short ram terminates in the engine bay and isn't that effective because it still sucks in the hot air from the engine bay; but the cold air goes outside of the bay to draw in cold air (hence the name). Most, however, go to the bottom of the car and forward, like he indicated, but turn directly right (toward the passenger side) into a void behind the bumper and ahead of the front passenger tire. Do a google search and you will see many, many examples.
Old 12-29-2003, 12:19 PM
Zcaithaca's Avatar
Zcaithaca Zcaithaca is offline
fershizzle
Send a message via AIM to Zcaithaca
Re: intake question
^^^^i agreee use google
Zach
Old 12-29-2003, 02:58 PM
Re: intake question
thanks for the help guys, i found a bunch of pics on google where they left the furthest left section alone, and being that im affraid of the bay looking empty, im gonna do it that way.
Old 12-30-2003, 03:20 PM
Re: intake question
okay heres what i got now..
I tried to make it like an Injen intake i saw on google
thanks again for your help guys
Old 12-30-2003, 03:23 PM
drumcat's Avatar
drumcat drumcat is offline
Re: intake question
this is off topic but shorty the link in your sig doesnt work
intake question Darkwing '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 42 11-02-2001 10:57 PM
Intake Questions 2K1 G20 Engine 13 10-09-2001 02:35 AM
ebay intake question greekman Engine 4 08-07-2001 07:42 AM
Intake question? DVSNCYNIKL Accord/TSX/Accord Hybrid 3 08-01-2001 09:20 PM
air intake question SkylinesKillAll Engine 18 04-27-2001 08:51 AM
