firewall? what the heck?
hey i ordered fog lights, and i searched up some install stuff. i know it pretty well, and i decided to take a look under the hood. i have NO idea where to put the wires through in the firewall. i seem some random openings, are they it? (i think they're holes for nut&bolts for other mods/options, because they seem to be placed close to another of the same size, assuming space for mount a bracket or something) ANYWAY. there are also some holes with a sponge-like material inside with a rubber plug covering it. (like the holes you use to install strut bars in) is that it? how would i take the sponge thing out? btw i have a 98rs. so if anyone else has a 3rdgen, and knows of a specific hole to get my wires through? thanks
ALSO: i have no idea how to find my wires once i get them through the firewall? i just want to make sure before i try anything...and get stuck yanno? thanks so much for reading the excruciatingly long thread, and thanks even more for your input. |
i guess u never installed an amp kit b4 then. yes, those holes should do fine, just make sure when u do put the wires through that it doesn't scrape or rub against the firewall hole. this can and might lead to cutting ur fog light wires and blow them out. to help eliminate this, cover the wire where it is passing through the hole w/ electrical tape, unless of course the rubber grommets is preventing ur wires to touch, then u have no problem at all.
Re: firewall? what the heck?
And you might have to peel some carpet back.
Re: Re: firewall? what the heck?
![]() Best advice: if there is hair around it go for the middle and aim for the wet spot. K P
... dirrtyyyyy...
go through hood relaese cable hole
.\/.ENIGMA.\/.
thanks i'll try that
now even if i do get through, how am i gonna find it inside? i wanna get it through the center console and past the tranny shifter to where the four option things are. how do i get the wire through so that i'll see it there? that's where i want my switch
I am interested in the same thing, but I want to use the stock wiring harness. I was told that the wires for the fog light option are in all wiring harnesses for integras. I already found the pigtail under the hood, but I cannot track it to anywhere inside the car. Am I missing something?
Now, pop out one of the blanks for the switch. Depending on what type of switch your use, you can drill a hole into the popout and install a switch in the popout or you can use a switch which will fit the hole left by the popout(Acura dealerships don't have any). Run the wire through the popout hole, connect your wires to the switch, install the switch in the popout or the popout hole, put everything back together. I've done this twice, once for foglights(stolen) and once for a switch so that I can leave my power antenna down while listening to the cd player(really easy and cheaper than a new antenna). Solder all your connections properly, use fuseible links, know where you are taking power from and the ramifications of using that power source. Keep everything neat and clean and out of the way of moving parts. Cover your soldered connections with electrical tape and use grommets and/or wire protector to avoid electrical fires... If this all sound complicated to you, it really isn't. Just take your time and do it right. I have blow many fuses and relays before by rushing and not taking my time to do it right. Have fun, and enjoy working on your car. |
gurgus has his shit down.....that is exactly how to do it. i ran an auxiliary switch for the power to my sub amp. jl w6v2 12's just hit too damn hard.
