Old 11-05-2003, 03:31 PM
mchthewanderer2003 mchthewanderer2003 is offline
Angry What the heck is rattling in the doors when I close them ???
Newbie owner of 1999 K1500 LS. My only complaing ... all the doors "rattle" when you close them. They also do it on larger bumps in the road. I'm guessing it has something to do with the window rails ??? The hinges seem ok, and door look like they're all aligned ok. Anyone else have any ideas besides opening her up and taking a look ??? Thanks room, CH!
Old 11-05-2003, 03:59 PM
Sexy beast's Avatar
Sexy beast Sexy beast is offline
Banned
Don't most domestic cars make that sound? I don't think you need to worry
Old 11-06-2003, 08:33 AM
Uh .... No ???
Just wondering what it is. Some common problems have common fixes, just trying to figure out if this is one of them.
Old 11-08-2003, 01:15 PM
blueburbboober blueburbboober is offline
dont listen to that import lover, just run him over hehe, j/k in all seriousness, they shouldnt rattle, my burb is as quiet as can be. i would yank the door panes off and see whats up. something may be loose or broken. you may als have some really small rocks in them?? i dunno, just some ideas. good luck man
-Rob
No more burb for me!!
2005 Jeep Wrangler. Blue, 4.0L
2004 Jeep Wrangler Unlimited. Bright green, 4.0L. No mods yet on either!
Old 11-11-2003, 08:20 PM
RattyPatty RattyPatty is offline
Send a message via AIM to RattyPatty
Re: What the heck is rattling in the doors when I close them ???
Yah i have the same problem with my passenger door when the window is down, only thing i can say is take off the panel and look around, it shouldnt be that hard
Old 11-24-2003, 09:07 PM
stubbornmike stubbornmike is offline
In regards to the door rattles;
you start hearing a noise when the ribets that hold the module to lock and unlock your doors start to become loose. They lossen after time from locking and unlocking so often. Just remove your door panels and drill out the old ribets and with a ribet tool install new ribets.
mike
Old 11-25-2003, 06:25 AM
jfmctlaw jfmctlaw is offline
what's a "ribet"?
Old 11-25-2003, 11:06 AM
Re: Re: What the heck is rattling in the doors when I close them ???
what's a "ribet"?
Sorry I should have been RIVETS.
A Rivet need to be install with a rivet gun..(like pliers but it hold the rivets)you can find them at your local harware store for less than 20.00 with lots of rivets. Practice with one first so you know how it works.
If you can change your oil you can install new rivets.
mike
Old 02-24-2004, 05:31 PM
alp2004 alp2004 is offline
I have a 99 LS 4x4 that was doing the same thing, especially with the drivers door. The outside drivers door handle cracked this winter so I had to pull the inside panel to replace it. I ended up replacing all the plunger style inner panel clips when I put it back to gether. I noticed afterwards that the rattle had disappeared. I suspect the panel clips had loosened up with wear. They cost about a buck a piece and it took ten to replace all the clips on the drivers door. Well worth it in my book.
What the heck is the spacer thingy behind the waterpump? CrapaTaurusWrecks Taurus | Taurus Wagon 3 10-13-2008 07:33 PM
Where the heck is the speedometer cable at the tranny? mark44004 ZX2 2 05-17-2008 12:16 AM
Where the heck is the heater inlet hose for the 2003 LS? Need to flush coolant! LordJezo Impala | Impala SS 0 04-26-2005 05:23 PM
Rattle or vibration when closing door luggage C/K 4 01-16-2005 08:58 PM
94 SE. Where the heck is the front door triggered light switch? BadAz117 Grand AM 6 12-01-2004 10:38 AM
