Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-28-2003, 06:51 PM
ramz434 ramz434 is offline
Exclamation 99 rodeo sunroof stuck open
Is there a way to manually close an powered sunroof. The roof is stuck open, I think it might be off the track, but my biggest concern right now is just getting it closed.
Any ideas?
Old 01-10-2006, 01:51 PM
InspiredByWalt InspiredByWalt is offline
Re: 99 rodeo sunroof stuck open
Any ideas?
Did you ever get a reply? I'm having the same problem. I went to the dealer and they tried a jump switch with no luck and was told there is no manual way to close the roof.
I'm wondering if the leak I'm seeing in the roof (drains clogged?) has shorted the motor and now needs to be replaced? Have you tried to replace any part of the sunroof?
Old 01-10-2006, 01:54 PM
directory's Avatar
directory directory is offline
of course you have checked all of the fuses...
the clog might be the culprit that burned out the motor. it would also help stain the interior. in order to manually close it, you'd have to remove the headliner and get up in there.
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
98 LTZ Sunroof stuck open pdigital360 Lumina 3 09-04-2007 02:02 PM
Sunroof stuck open Help !!! lazer2463 Grand Prix 1 05-11-2006 09:40 AM
Sunroof stuck open on tilt cjvento Golf 0 12-16-2005 01:22 PM
Rover 620 Sunroof stuck open! monkey123 General Discussion 0 07-31-2005 06:29 AM
Stranded in Maryland with sunroof stuck open! chimay 3 Series 5 03-01-2005 04:35 PM
