Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-28-2003, 11:18 AM
motormike40 motormike40 is offline
Send a message via AIM to motormike40
how should I tubro a stock LS
im thinking about getting a 93 civic hatch and putting in a b18a and turbo, but i dont know what turbo will give me the quick spool and boost down the road.Also is using an FMU better then new injectors, its cheaper so im leaning towards that,but how much boost can i push with the stock motor. i had a buddy who pushed 14psi and used a 50 shot and lasted him for 8 months, but im looking for it to last a bit longer and run that hard, i dunno im just looking for feedback on turbos and my idea. Anything helps thax alot
P/S does anyone know of a good turbo kit for an LS motor?
Old 12-28-2003, 04:52 PM
CougarSVT CougarSVT is offline
Send a message via AIM to CougarSVT
Re: how should I tubro a stock LS
T3/T4E54, 0.63, stage II, Ball Bearing Turbonetics Turbo. With a Racegate wastegate and you have a great start....Fast spooling with that turbo and elimanate "boost creep" with the Racegate!! And yes we carry a Turbonetics kit for your car. It has new fuel/timing upgrades and can go to 10psi safely. I would stay at 10psi or lower.....more boost the more that could go wrong. You would be very happy with 10psi anyways.
Good luck!
Dealer for Turbonetics products...cant beat our price!
Dealer for SCT......fine tuning software
T3/T4e, super series, Hybrid, stage III Turbine $650.00+tax
T3/T4e Ball Bearing, Hybrid stage III Turbine $1,050.00 +tax
Turbonetics EVO wastegates...$200.00!!!
Turbonetics Raptor Bypass Valves
Turbonetics Turbo kits for Civic's, Preludes, GSR's for $2,999.00!!
Spearco IC's from $225.000
PHONE #: 937-336-1462 ask for Stephen N Brown
********HAPPY HOLIDAYS********
Old 12-29-2003, 12:20 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: how should I tubro a stock LS
you can do 12psi if you change the head gasket but i dont recomend it all the time like cougarsvt said 10psi on stock internals.
1
Shift_BOOST
97 s14
Old 12-29-2003, 03:42 AM
TuRBoHaTcH TuRBoHaTcH is offline
With the stage II Ball Bearing Turbonetics Turbo running at 10 psi, what type of hp gains are u looking to have? this all on a stock ls motor...
Old 12-29-2003, 10:09 AM
HP gains
thx y'all it helps alot, but my goal HP is around 250, thats a respectiable amount. im thinking about pushing 10-12psi when i race but when driving tune down to about 3-4 psi. im thinking it may perseve my motor.
Old 12-29-2003, 12:56 PM
You can have up to 400+HP if needed. But at 8-10psi you should be near 225-275HP with a very fast spool time. That Turbo is the best i have seen out there....and dont be fooled, the Turbonetics BB can be rebuilt unlike Garret and others that cannot once they go bad.
i want to build up my d16z6, how should i do it 94hatchsi Let's get Technical! 30 10-22-2011 03:41 PM
what should the stock MPa be? iT90accord Impreza/9-2x/Outback Sport 5 06-08-2004 07:11 PM
How should i hook up a 99' Civic ex coupe? mystdotcom '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 35 03-21-2002 04:03 PM
How much do stock 2001 prelude rims cost? Lingerie_Ripper Prelude 4 02-01-2002 07:24 AM
