Old 12-27-2003, 02:41 PM
phabfore phabfore is offline
4x4 won't unlock with electronic switch
I have a 94 s-10 blazer 4x4. The 4x4 is locked in low. It won't release with the electronic switch. I have a chiltons auto guide,but it doesn't help with troubleshooting. What should I look for?
Old 12-28-2003, 09:40 AM
joshzr2 joshzr2 is offline
I would say your switch is probably defective. If I were you, I would take it to a professional. If you can, I would recommend having the electronic transfer replaced with a manual transfer. You'll have a lot less problems out of it. You could still have problems with the manual transfer, but they will be a lot easier and cheaper to fix.
Old 12-30-2003, 04:17 PM
GMCMAN GMCMAN is offline
Re: 4x4 won't unlock with electronic switch
Hey Phab,i Am Having The Same Trouble As I Write This The Gm Mechanic Said That It Has 2 Transfer Solenoids And That One Is Stuck They Are Located At: 1 Is On The Front Bell Assembly And The Second Is On The Transfer Itself But The Switch Is Usally Fine,not Saying Yours Is But That Is What He Told Me
Good Luck
1997 Silverado Ext Cab 4x4 won't engage Sward83 Silverado 4 02-13-2011 12:34 PM
2000 venture van won't unlock...with the door buttons ruralways Venture 6 05-09-2007 08:22 AM
Electronic 4x4 won't disengage Jimmy95 Blazer 12 03-01-2005 08:01 AM
drivers door & trunk won't unlock with remote wiseguy_75 Cavalier 4 02-22-2005 03:20 PM
Drivers side door won't unlock with power locks ghutchin Aurora 7 04-17-2004 12:05 PM
