93 Integra: (This happened on my 88 Integra too)...lately if I shut off the engine and then have to restart in a short amount of time, the engine will crank but not turn over. Usually waiting a few minutes will help. Trying too many times too quickly runs down the battery and it won't start at all. BUT, worse, while DRIVING, the engine has died - rpm's just go to 0. It luckily comes back alive in a few seconds.
Help!! (On the 88 it was difficult to diagnose, but once mechanic figured it out it was relatively uncomplicated - but I can't remember what it was...don't want to spend tons of cash having them check every little thing again). |
It could be the alternator, and check to make sure the cables are securely connected to the battery.
My bad... you may even need a new battery. Check to make sure its in good condition.
Re: Engine Dying/Not Starting
Have been doing more research - seems there's a common problem with hondas/acuras and the ignition switch and/or main relay. Heard of anything like that?
jajdiver is right, or in my case n e waays, thanks man.
Re: Re: Engine Dying/Not Starting
ok, changed ignition switch, but it died again.
now it's completely dead - won't turn over ever (still cranks). i hear the main relay click, though. and it's winter (in california, so not freezing, but not hot at all)... so any more thoughts? Quote:
93 teg LS B20B![]() ACT Performance Flywheel AEM CAI DC Sports Stainless Steel Header G4 High Flow Cat GReddy MX Cat Back Exhaust Skunk2 Racing Chip Lots of interior goodies |
I have a 97 civic lx manual, and it died on me twice while I was driving normally. I had my subs and lights on, so it may have been the battery, but is sounds like you might have some problems with the spark plugs or the ditributer. My friend had the same problem with his car not starting, he got a new battery and everything was fine. it would crank over but it wouldn't start. good luck
Consensus at the shop was a bad distributor. There was no spark whatsoever - so a freakin fortune later, I'm up and driving again.
The relay fixed my problem. Try your battery and electrical system. then try your ignition system.
