Old 12-26-2003, 08:35 PM
kiosanim2 kiosanim2 is offline
programing
Hi there I have a 2000 tahoe LS need to know how to program my keyless entry remote.thanks
Old 12-26-2003, 08:38 PM
Re: programing
I need help to program my keyles entry remote for my 2000 Tahoe LS
Old 12-26-2003, 10:02 PM
99ssconv 99ssconv is offline
Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds. The locks will again cycle once.
Repeat step #2 for each additional keyless entry transmitter.
Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete
Resynchronization may be necessary due to the security method used by the RKE system. The transmitter does not send the same signal twice to the receiver.
The receiver will not respond to a signal which has been previously sent. This prevents anyone from recording and playing back the signal from the transmitter.
Resynchronization will be necessary if any of the following are true:
You change the transmitter battery.
You disconnect the vehicle battery.
You push the transmitter button 256 times out of the range of the receiver.
In order to resynchronize the transmitter with the receiver, perform the following steps:
Stand close to the vehicle.
Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for seven seconds. The door locks should cycle to confirm resynchronization.
Old 04-02-2004, 10:04 AM
MyHoe MyHoe is offline
1998 tahoe
Hi, does this trick work for a 1998 tahoe as well? I just bought one of these of ebay and its on its way to me. But I dont want to go to the dealership to get it programmed. So I just want to know will this work on my year too.
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 03:54 PM
How to put BCM into program mode? (Where is BCM/MALL fuse?) copchick527 Grand AM 5 03-02-2009 04:30 PM
Programming Instructions for programming instructions EZSDEI474V eddiem Engineering/ Technical 1 03-18-2005 06:15 PM
