Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-26-2003, 02:39 PM
TonyHolla's Avatar
TonyHolla TonyHolla is offline
Send a message via AIM to TonyHolla
Need turbo guidance?????
I have a bone stock 94 B18B and I want do an engine build up the right way for a turbo and a lil nitrous and I’m planning on running my turbo at low boost. Bottom line I want a strong reliable engine so I can get to work fast and I want to be able to do most of the work on my own. Can you point me in the right direction?
PLEASE USE TURN SIGNALS THEY ARE THERE FOR YOUR AND THE SAFETY AND OTHERS AROUND YOU AND IF YOU GO 65mph IN THE PASSING LANE MOVE TO YOUR LEFT I HATE BLOWING PASS PEOPLE ON THE RIGHT.
Old 12-26-2003, 03:48 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Need turbo guidance?????
you need to re-do the bottom end, maybe put sum cams, and new fuel managment
bottom end
pistons
rods
piston rings
knife edge crank
re sleaved block (option)
lower compression to about 8.5\9:1
and a new head gasket
as for fuel managment, i say get some good injectors 450cc-650cc and new fuel pump and regulator and some thing to control it all like a hondata or if you dont want 2 spend so much get a boost controller and a air\ fuel controller.
1
Shift_BOOST
97 s14
Old 12-26-2003, 10:00 PM
ewing86 ewing86 is offline
will since you really wont do any of the above, its waste because you;ll never turbocharge your engine for the main fact that if you have to ask what you need to do than you wont be doing it. And to point you in the right direction, figure out how cars work before you go modding them, jacka$$
Old 12-27-2003, 07:33 AM
CivicEXRider's Avatar
CivicEXRider CivicEXRider is offline
No one ever ask's what is best to get an idea what to do first and the right track to do it in. OH PLEASE! I've asked a bunch of questions before I started and now I drive around in a pretty fast economy car The economy car
Since you have a B18B that's the best motor to turbo with the stock bottom end. No need for a build up right away. Get a Drag/Rev hard Fmax turbo kit and boost it all day at 12psi. After that, while saving up some cash, you'll know alot more about what you want to do next and the power goals you'll want to reach.
Old 12-27-2003, 01:23 PM
TonyHolla's Avatar
I ‘m here to learn I don’t know much that’s true and what’s a better way to learn then to tear into your own shit my fault for getting a late start and not knowing much. I’m a member here because people other than you have knowledge, insight and experience but you would have to be the you get my point. Have a good New Year and be SAFE
Need some guidance mazingo Malibu 8 08-27-2006 05:57 PM
Heater core leak... needs replacing... guidance? Steve in Indy Ranger | Courier 2 11-06-2004 08:22 AM
New Stratus Owner....Need some guidance 00stratusSE Stratus 1 07-24-2004 08:18 AM
Dropping in a stock LS motor and need some guidance Hybrid1990crx Integra 0 05-13-2004 08:05 PM
need some guidance here... helping a friend 97gsr Camry/Camry Hybrid/Vista 2 01-03-2004 08:15 PM
