Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-24-2003, 09:06 AM
Dennosmith Dennosmith is offline
99 Rodeo -- OBD code P1627
Does anyone know what this code is? I looked it up and it means
"PCM A/D Conversion Malfunction." What is this and how do I fix it? Please help....
Old 12-24-2003, 09:43 AM
paulsantangelo paulsantangelo is offline
Re: 99 Rodeo -- OBD code P1627
It could just mean that your code reader does not function with the ECM. Can read the codes!
--just a thought!
It could just mean that your code reader does not function with the ECM. Cant read the codes!
--just a thought!
Old 12-24-2003, 09:58 AM
rodeo02 rodeo02 is offline
Denno- I'm guessing that code means "analog to digital conversion". I've never seen that one come up! do you have any other symptoms? How old is your battery? I know our zu's are super sensitive to proper charging system output (needs a steady 14v with truck running). The only other things I can think of is check all the ground connections. G/luck! keep us posted.
Joel
Old 04-02-2004, 08:10 AM
bfn311 bfn311 is offline
were you able to fix the problem. I have the same code.
Old 04-02-2004, 07:31 PM
I had the PCM replaced--tied to another problem...but still have the code. I think it is tied to the fuel sending unit. When my CEL come on after my fuel gage acts all wierd, I get the P1627 code. When the CEL goes off and I clear my code, I don't see it again until the fuel gage acts up again.....
Old 04-04-2004, 09:03 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
if p1627 is set there should be another DTC for Dennosmith it will be (P0463 fuel level sensor high input) you need a fuel sending unit. Not all code readers do a very good job of code reading take it to your dealer parts are $45 and labor should be 2.5 hrs or do it yourself its not hard
Old 06-13-2009, 01:00 PM
jimmypodunk jimmypodunk is offline
I have a 2001 rodeo sport with the following codes. P1627, P0463. The fuel guage acts all wierd and goes to empty when it's nearly full and I get a fuel low light along side with it. I plan to change the fuel tank sending unit. If it clears the P1627 code I'll follow up and post something here.
Other codes I have that I think are unrelated are P0402 EGR, and P0128 coolant thermostat.
Ruh Roh George!
Trouble code P1627 Spooky50 Rodeo | Passport | MU 1 11-22-2009 02:51 PM
HELP on some OBD II Codes royto Stratus 2 08-09-2009 07:14 AM
1999 Amigo fuel level sending unit code P1627 OldChevys Amigo 8 09-26-2006 08:35 PM
1995 Rodeo, OBD 2 connector whereabouts ejb22 Rodeo | Passport | MU 2 07-20-2006 10:11 PM
99 rodeo OBD II PO171 problem lostkidd79 Rodeo | Passport | MU 3 04-04-2004 08:58 PM
