Old 12-24-2003, 06:55 AM
Oliver77 Oliver77 is offline
Question Intake Manifold water leaks
My 2000 Silverado 4.3 is starting to have a problem similar to a 97 Olds 88 we used to have. The throttle sticks in the closed position and it takes a hard punch to loosen it. When this happened on the Olds we found that the upper intake plenum had a coolant leak and the lower plenum was full of a coolant. This apparently was a common problem on the 3.8 V-6's, and GM made a change to the intakes to eliminate the it. Does any problem like this exist with the 4.3?
Old 12-26-2003, 09:27 PM
99ssconv 99ssconv is offline
you need to clean the throttle body plate with carb cleaner, when was the last time it was done? recommend at least every 30,000 miles.
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
silverado intake manifold water leak scottdombeck Silverado 13 10-12-2008 12:33 AM
Intake manifold water gaskett leak? Blownpiston Metro 2 09-07-2005 06:58 PM
