Old 12-23-2003, 11:05 PM
chuckie4373-3 chuckie4373-3 is offline
Send a message via AIM to chuckie4373-3 Send a message via Yahoo to chuckie4373-3
1995 Chevrolet Blazer transmission problems
When I first start driving my Blazer in the morning it acts as if it is really low geared. You can set the cruise control at 55 and when the temp gauge reaches half way between cold and normal the tach will drop 400 RPM's without any speed loss. Sometimes it will repeat the same thing once the ignition is turned off but not always. It will never repeat it without turning the ignition off. I had it checked at a transmission shop and he said they were all like that. I can not believe that. If anyone has any ideas, please let me know.
Old 12-24-2003, 04:53 AM
vinnie97 vinnie97 is offline
yes this is normal. it is your torque converter locking up. it gives you better gas mileage. mine does exactly the same thing.
Old 12-24-2003, 08:57 AM
Jethro_Canada Jethro_Canada is offline
Re: 1995 Chevrolet Blazer transmission problems
I was talking to a GM mechanic with a 94 Safari Van, 4.3L, we got talking about this and he says he van does the same thing, the way he explained it to me was that theres a valve in the tranny that wornout the will not allow it to drop down, once it warms up its fine. Mine does it to, on really cold days I just fire the truck up for 15 minutes and let that tranny fluid cycle trough that rad, once its warm no problems.
Old 12-24-2003, 07:18 PM
Re: Re: 1995 Chevrolet Blazer transmission problems
OK, I can understand the need to warm up the transmission to get that valve to work correctly, but why does the transmission sometimes do that when it is already warmed up after the ignition is off for as little as 10 seconds (like if the engine dies).
Old 12-26-2003, 07:19 AM
Re: Re: Re: 1995 Chevrolet Blazer transmission problems
Maybe it takes a couple of minutes for the pump in the transmission to get caught up to after the engine being off?
1995 Astro Transmission Slipping Dannoastro M Bodies 5 02-12-2011 12:07 PM
1995 Chevy Blazer 4wd Problems Scottm69s Blazer 1 02-01-2011 07:09 PM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
2004 s-10 blazer transmission problem 04chevyblazer Blazer 3 06-25-2004 09:27 PM
1995 Chevrolet Suburban Transmission Jack Marshall Sierra 0 10-04-2002 01:19 PM
