Old 12-23-2003, 07:18 PM
bones189 bones189 is offline
Here are the sympthoms, anyone know the diagnosis
The truck, 95 Tahoe. Sympthoms: Intermittent grinding sound on take off mostly, sometimes later. If I put in 4 wheel, grinding goes away instantly. No sound in reverse in 2 wheel. Checked actuater on front axel, working good. Transfer case problem?
Old 12-25-2003, 05:44 PM
2DrTahoeBen 2DrTahoeBen is offline
Send a message via AIM to 2DrTahoeBen Send a message via MSN to 2DrTahoeBen
I don't know if this helps or not, but I used to have a 1988 bronco and right before the whole rear differential went out (along with the front a couple weeks later ) I had that same problem. Once I got over abotu 25 mph, the grinding would go away. When my rear went, the dumbass tow truck guy towed me incorrectly and ripped out my transfer case, so I guess it could have been that too, but AAA payed for it all, so it ran fine after that... hope it helps a little..
Ben
Old 12-26-2003, 09:06 PM
99ssconv 99ssconv is offline
Remove the rear transfer case housing, just remove the rear driveshaft and then the housing, around 5 bolts retain it. Once off look for a broken snap ring that hold the mainshaft in place just behind the rear bearing. The snap ring is around $11 plus the anerobic sealer to reseal the housing. Takes about 30 minutes to repair. Good Luck
does anyone know the diameter of the foglights are on a 98-02 bird i want a dirtybird Camaro Discussions 3 01-05-2005 04:32 PM
ANYONE know the quarter mile times for the z3.0 and 2.8 brunoshogun Z3 2 08-19-2004 07:48 PM
Does anyone know the hp/ torque and also what the tire size are on a 2002 Cavy!!!!??? 02'CavOwnr Cavalier 0 12-11-2003 03:27 PM
ANYONE know the SPECS on the Mcoupe or roadster brunoshogun Z3 0 07-12-2002 03:19 PM
Does anyone know the true redline of the ZC? 90CRXZCSi '71-'87 Civic | CRX 8 03-09-2002 02:50 PM
