Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-23-2003, 04:44 PM
SniperX13's Avatar
SniperX13 SniperX13 is offline
Send a message via Yahoo to SniperX13
Question Transmission Slippage
What are signs that your transmission is starting to slip? What causes a Transmission to slip? How much does it cost to get it fixed? Thanks for the Help.
"Who are we to judge those, when we ourselves are afraid to be judged."
Old 12-24-2003, 10:19 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: Transmission Slippage
Is your transmission manual or automatic?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 12-24-2003, 11:37 AM
454Casull 454Casull is offline
If you have a big metal box somewhere under the hood connected to the engine, your transmission slips.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 12-26-2003, 10:56 PM
pod pod is offline
gee and all this time i thought it was the transmission
30 mpg in a brick on wheels isnt half bad...
Old 12-27-2003, 01:51 PM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Well, an easy way to check if your tranny is busted, will it EASILY shift into reverse when you are at a stop?
2. while driving down the road, down shift and release the clutch. If all goes well, it's ok.
Mustangs are nice, but I'd rather have one of these...
Old 12-27-2003, 03:32 PM
SniperX13's Avatar
Re: Re: Transmission Slippage
I'm sorry guys, I should have stated... I have a 1998 Ford Taurus with the 3.0L Duratec, and its a automatic.
Old 12-28-2003, 12:44 PM
Jporter12 Jporter12 is offline
Send a message via AIM to Jporter12
Why are you questioning it? Do you have a particular concern?
When the transmission slips, it can be from many causes, but they all come back to one thing, low pressure to the clutch or band that is slipping. This could even be just from the clutch pack or band being worn out. Low fluid level has caused many transmissions to slip, and even ruined quite a few!
A typical overhaul for that transmission should run around $1400-1600 unless there is something badly broken.
Old 12-28-2003, 11:23 PM
SniperX13's Avatar
well, when I first start out, I am not sure if its just because its cold, but the car shifts real hard, and when its downshifting (after warming up) the car shudders a bit sometimes when the car drops into first and the rpm's drop really low, to about 600 or so from 2nd to 1st.
Old 12-29-2003, 09:26 AM
the ford AODE is pretty pathetic really.
most mustang guys have to replace them with sturdier models when doing any serious modifications. Usually for the cost of a good rebuild, you can just buy a new one, which is nice.
from what your describing, it could be the TPS, which is the throttle position sensor. I had a similar problem on an oldsmobile I used to own, the transmission would think I had the gas planted when I didn't, etc. check that and then check the fluid also.
Old 12-29-2003, 10:40 AM
SniperX13's Avatar
thanks for the advice, I'll check it out as soon as I have the time.
Old 09-20-2006, 03:04 PM
dminor42 dminor42 is offline
what causes transmission slippage
Old 09-20-2006, 05:10 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
This thread is 3 years old, try starting new one, with a much clearer, better defined question, including more details about the car and transmission in question.
Transmission Problem? elcamino6t9 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 11-19-2010 08:23 PM
New Transmission Fluid cause slippage DallasMEF Explorer | Explorer Sport Trac 3 06-15-2009 08:30 PM
Transmission slippage please help!!! mymachine Grand Cherokee | Grand Cherokee SRT8 21 01-09-2005 02:23 PM
transmission slippage lmkeehn Engineering/ Technical 2 08-24-2004 12:45 PM
Transmission slippage... rruddfan21 Metro 1 02-26-2004 04:30 PM
Closed Thread
