Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-10-2009, 07:38 AM
DallasMEF DallasMEF is offline
New Transmission Fluid cause slippage
2 months ago, I changed the transmission filter. Nervous about doing anything with the fluid, I went back in with the old fluid and car has been running fine.
I convinced myself that I need to begin upgrading my old fluid, so I siphoned out 2.5 Q of fluid and replaced with new fluid.
Immediately, on my test drive, the transmission started slipping/flaring after the engine warmed up. I read that new fluid is high in detergent and cleaned the varnish off of the internal parts-band/drum, etc.
Any help out there?
Will adjusting the bands help this situation? It is pretty safe to say that none of the shift sensors, clutches and bands are not broken, since it was shifting fine before I added the 2 qts of new fluid.
What about LucasFix? What exactly does it do? The bottle says it cleans and lubricates worn out bands and valves. If it removes varnish, it seems that will only complicate my problem.
Old 05-12-2009, 08:28 AM
virgamanda virgamanda is offline
Send a message via AIM to virgamanda
Re: New Transmission Fluid cause slippage
What type fluid did you use? Most Explorers take the Mercon IV Tranny Fluid. I am not big on any of those additives, if the wrong fluid was used you may have to take it in for a flush.
Old 05-12-2009, 09:33 AM
I used the owner's manual recommended Mercon V.
I found several postings from some transmission experts that I am posting here for others to see. It seems that improperlymaintained transmissions causes the fluid to take on varnishy characteristics. In theory, this varnish and clutch material particles allow the internal parts to still grab....even when the tran fluid has broken down and the friction material has worn off of the bands. New tran fluid is highly detergent and will strip this varnish - which removes its ability to engage and "stick" to change gears.
http://en.allexperts.com/q/Lincoln-M...sion-fluid.htm
http://www.rd.com/104259/article104259.html
http://www.trustmymechanic.com/transslip.html
Old 06-15-2009, 08:30 PM
truck150 truck150 is offline
i did the same thing and filled it to the specs and trans didnT work i proceeded to put more fuild in and it started to work. again i overfilled mine to get ti to work so now that i know it still works it is going to the dealer tomorrow to have it professionally serviced and done correctly. i don't think there is anything wrong with your trans it just needs to be serviced by someone who knows how to work on the dumb designed trans. ford really had there heads up there ass when they designed these trans and made it impossible to work on hope this helps
Tags
bands , flare , fluid , slip , transmission
