Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 12-23-2003, 09:56 AM
joeped joeped is offline
Question Trouble starting 99 Tacoma
Has anyone ever heard of Having trouble starting the 99 Tacomas. I just picked one up and noticed that sometimes I have to put all 200 lbs of myself on the clutch to get the thing started. I brought it back to the dealership and they told me they've never heard of it, which I think is BS. Any info would help.
Old 12-30-2003, 12:55 PM
newkansan newkansan is offline
In my tacoma it is the same, have to put it to the floor and practally stand on the clutch to get it started.
I have fond that sometimes the two bolts holding the clutch on come a little loose. I think this has someting to do with its ability to trigger the switch.
After tightning it usually resolves the problem until it loosens up again
rodney
Old 01-05-2004, 12:53 PM
Re: Trouble starting 99 Tacoma
thanks for the advice, I knew I wasnt the only one with this problem
Old 01-11-2004, 06:41 AM
llewsob llewsob is offline
I just bought a '99 tacoma and I have the same situation.
I will look for the the bolts and tighten if necessary.
THanks,
Old 01-17-2004, 09:37 PM
95TacoTruck 95TacoTruck is offline
Send a message via AIM to 95TacoTruck Send a message via MSN to 95TacoTruck
Do the newer ones have a clutch cancel switch under the driver A/C vent?
Old 01-19-2004, 04:53 AM
99 does.
my old 94 did.
Old 01-21-2004, 03:18 PM
were these clutch cancellation buttons created for this very problem? I was told that its purpose was for using it on steep inclines requiring a foot on the brake and gas at the same time. However, I need to use it just about everyday just to start it.
Old 01-22-2004, 02:35 PM
It has come in handy for me, when I run out of gas and need to move the truck another 25 feet to the pump. Push the button, car in gear, move the car w/ the starter.
Old 01-22-2004, 07:59 PM
Rockgate Rockgate is offline
I had a 99 ex-cab and the same thing happened. I thought something major was wrong, but the clutch switch behind the pedal come unplugged.
Old 01-24-2004, 06:40 AM
'03DC3.4TRD4X4 '03DC3.4TRD4X4 is offline
Be Careful!
Just remember that you should only use the starter to move the truck for 15 seconds at a time. The starter generates heat and needs to cool after continuous use.
The purpose of this gadget is to allow you to continue when traction fails otherwise (tire spinning, etc.)
It has saved me on numerous occasions!
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 03:56 AM
87 2WD Pick Up - Two Decades of Starting Problems MSW78 Older Pickups 5 11-21-2009 09:45 AM
95 Mustang 3.8L-trouble starting... DDP87 Mustang Problem Diagnosis 3 09-27-2009 08:47 AM
Trouble Starting My Tacoma DAVID MADONNA Tacoma 13 12-20-2004 07:25 PM
95 Tacoma Trouble Starting When Warm goliath11 Tacoma 34 10-07-2004 06:08 PM
