Old 12-22-2003, 02:54 PM
93DXon18s 93DXon18s is offline
D15B7 Upgrades.....
i want to upgrade my 93 Civic DX D15B7 so i have a few questions for anyone who can help me............
1. whats the best cam to use for the most gain possible?
2. will a compression change improve or decrease engine performance HP and Torque wise? if not, what will give me the best compression on 93 Octane with a mostly stock D15B7 engine?
3. best plugs? best wires?
4. best Throttle Body that can be swapped?
5. i have been told that a Y8 intake mani will be a direct swap and that a gsr or and LS throttle body can be swapped for better performance. true or false? and if true, which year for both
6. anything else i can add or swap to my DX engine which will creat more HP and Torque and give and all together better performing engine???(dont tell me to swap in a better engine, if i wanted to do that i wouldnt be asking for D15 upgrades)
i know this is probably alot of questions but i really want to upgrade the stock engine i have and any and all info would help, thanks ahead of time.
Old 12-22-2003, 03:34 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: D15B7 Upgrades.....
I've learned swapping engines is better than pouring perfume on shit, and both cost almost the same.
Old 12-22-2003, 10:36 PM
i just learned yur a nerd. If i wanted stupid comments like this i would have changed the topic to 'send stupid comments this way'. Unfortunately, the topic is about me wanting to upgrade the engine i already have, it has nothing to do with racing or shows or some stupid shit like that, i just want to upgrade my engine so it will perform better for ME not anyone else or against anyone elses car. Please stick to what the topic is about. lol i knew after i posted this, some moron would have to say something about swaps, even after i specifically stated i wasnt going to swap my engine out lol just goes to show how some assholes need to speak their minds anyways lmao
Old 12-23-2003, 12:54 AM
pheurton-skeurto pheurton-skeurto is offline
okay okay...calm down. ricochet knows his shit first off. look at his car. hes done the things to make it the best car for him. similar to what you want. theres a certain level of respect floating around AF and the people who learn to develop it, while ignoring those who they feel dont, receive the comments and treatment back...
alright, on to your d15b7: i have had a 95 civic lx (same as your car, with the d15b7) for about 4 years now. i love the car, so i know how you feel about messing around with a swap. to be most acurate, im going to answer your questions in order:
1. ive yet to find an aftermarket cam for ANY d-series engine...sorry, if you do find one please, please PM me with it. id love to see it.
2. this is where i strongly hint/suggest a swap. changing the compression requires new pistons/rings, which requires removing the d15b7 from the engine compartment. with the engine out of the compartment, why not take the money you would be using to upgrade for a new engine...get my point. also, you will find that this engine (stock or close to stock) actually runs better on 87-90 octane gas...YES, im serious. do some research.
3. unless your plug wires are in very bad shape, you will notice no power gain with aftermarket ones. although you will notice slight (maybe 5hp) increases in power with an aftermarket digital ignition from a company such as MSD.
...okay and as for the throttle body and manifold questions are concered...rediculous. those mods, after you spend the time and money finding/installing those parts, the gains are going to be somewhere in the 8-10hp range, and even with everything youve mentioned youre still looking at nothing more than 120 hp, up from the stock 107hp and 98lb/ft of torque...
you can be stubborn all you want, if 120hp is what YOU want out of YOUR car then thats YOUR problem. if you were wise with your money youd look into a b16a3 or the b18b1...both of which you should score for under $2000, and both of which have around 150 stock hp and much better capabilities than the measly d15b7...
1997 Honda Prelude Base
18G Turbo - 8 Psi
GReddy EVO Catback
1995 Honda Civic LX
Bone Friggin' Stock
Old 12-23-2003, 01:37 AM
1. i dont have that kind of money to do a swap........which is why im not going to do a swap.
2. what i meant with the cams is, ive read MANY times that an Si cam from the same year would be good for gains and would be a noticeable improvement in power and response.
3. i dont have problems with anyone in AF, i just get frustrated when someone says i should spend a few grand or so like its no problem. If i could do that, i wouldnt even be a member to AF, i would just have my car done the way i wanted it to be cause i would have the money to spend on it. Unfortunately i cant come into that kind of cash quick enough, therefore, i can only afford small things for the engine i have (this does not include a new engine and/or tranny). i have an AUTOMATIC 1993 civic dx that is stock except for the 18 inch Primax's wrapped in Kumho Ecsta Supra's, coilovers, an intake, new plugs, and a JDM (yes, its really from Japan) cat converter . i want to switch to standard, get a body kit, exhaust, and finish my interior that i started. this all takes alot of time for me and alot of time to get the money i need, thats why i blew up in the reply i wrote. lol i need things cheap i guess lol
p.s. what i really want is something different such as the JDM 3 stage VTEC D15 which boasts a decent 130HP and is used in the Ferio VTi's, but i cant find one for a few hundred dollars.
Old 12-23-2003, 09:28 AM
Ricochet's Avatar
Banned
You can spend a few grand on little pulleys, cams, intake, header, exhaust, yadda yadda yadda, and wow you end up with a whopping 20hp gain or whatever. The reason I said swap is because I've been in your shoes, spent enough on my DX engine to turbocharge it, and I was never happy with it... even with nitrous. That's why I'm telling you to swap, so you don't make the same mistakes I (and thousands of other people) have done. Swap or turbocharge your engine. Also if you have big heavy 18" rims, that tears away all kinds of power.
Old 12-23-2003, 01:44 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
cam, compression change, plugs, wires, Throttle Body, intake manifold...
just to change the cams and to build the engine for higher comp it will be at least 1000 for parts.
throttle body and intake manifold are also pricey.
i bet by the time you get this small amount of mods which honestly will only give you at most 40 hp more ( this is a very generous figure since I don't think you will be able to raise the comp too much) you will have easily spent close to 2000.
I don't wanna cause problems but honestly even a cheap ass b18a1 will give you better hp and torque than you will see with these mods, and I bet you could pick one up for less than 1000 with a tranny at a junkyard or something.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 12-23-2003, 11:47 PM
an automatic to manual conversion is over a grand.
a decent kit (kit+paint+installation) is over a grand, while doing nothing for hp #'s.
i give up.
18G Turbo - 8 Psi
GReddy EVO Catback
1995 Honda Civic LX
Bone Friggin' Stock
Old 12-24-2003, 07:54 AM
Thumbs up
nope, i can get a 5spd tranny for like $300 and have the swap done for free, and done right. Also, i found a place where i can get the kit i want for around $400 shipped; and this guy i work with, his father does paint jobs so....your expected cost just went from like $2k to like $800-$900. the most costly thing so far is the engine/tranny i want which is the JDM 3stage vtec d15 with multimatic tranny and i just got quoted @ $2715 crate shipped from Tokyo, Japan. This engine keeps up with b16's. With a little effort on my part, could have this all by mid-summer...hopefully lol thanks for the info tho, even if i sounded like i was being an ass, you guys still gave me some good info.
Old 12-24-2003, 03:19 PM
unusualcivic's Avatar
unusualcivic unusualcivic is offline
Send a message via AIM to unusualcivic
what is the point in paying $2715 for a JDM engine, when you can go to a parts yard, spend $1000 or so for a good B-series (which consequently have very good aftermarket support, more than the D-series anyways) and still have $1715 to play with???
its DUMB to pay over twice as much for a lower powered engine just because you see "JDM" somewhere on it. If you get a JDM engine, you run the risk of not passing emissions inspection (if applicable).
84 Civic 1500S
engine- T3 D16a1 with built bottom end in the works
interior- MOMO seats, Sunpro guages, RCI 4-point harness,
sound system- clarion DXZ825, RF Fanatic P's RF 351S, 1 Eclipse SW6123DVC (currently saving for another)
exterior- satin black in progress
Old 12-24-2003, 05:14 PM
Ricochet's Avatar
Banned
Re: Re: D15B7 Upgrades.....
Please give me a name of the junkyard selling a B for $1,000... The lowest I've seen a B16A1 at a junkyard exceeded $1,500-$2,000 I've even seen 96-00 1.6 EX engines go for $900 with ECU's. If you find a B-series for a grand, do yourself a favor and don't buy it. 99% of the time you get what you pay for when it comes to engines.
Old 12-24-2003, 05:56 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Okay, you say you "don't have the money to swap"...the you turn around and say, and I quote
I mean, stop fooling yourself, get real. okay
1)Stop being suck an ass to Ricochet and others who suggested a swap. First off, putting that in IS A SWAP. it requires the tranny, motor, and vtec ecu. Stop kidding yourself, you said first you wanted to "build up the D15B7. The parts you want alone wil be more than a grand, and that's assuming you do the install. Then you say you want to put this in? This IS NOT building up your stock D15B7. This is called swapping in a JDM D15 vtec for $2715. Buy getting htat, you ARE INDEED AFFORDING A SWAP. Furthermore, for $2715, you can certianlky get a B16A or a B18B1 in there. I don't care what you think, either of those motors will that that D15vtec stock for stock, and when you decided to build them up, have way more potenial.
2)As mentioned above, you want and seem to be able to afford a $2715 swap for a.....Vtec D15?? I don't give a shit where the motor is from, Japna or not. Who cares if it's a Vtec JDM motor. JDM is overrated in that sense. Just cuz it's JDM doesn't mean it's cool or good. Don't beleive me? Check out what the "JDM" direct power system" turned out to be. Just cuz it's from Japan doesn't make it a good product.
3)As enluded to in the above statement, if you can afford $2715 for a JDM D15 Vtec motor, you sure as hell can afford to swap in something else besides that motor, like an LS or a B16A.
4)Doing a mini-me conversion would be cheaper and cost less than the $2715 you intend to pay for a jdm d15 vtec. You'll have $$ left over to mildly mod the motor afterwords, and the HP output will be similer to the jdm d15 vtec...and for a lot less.
5)If you are stuck on getting the D15 vtec or building your own d15b7 up, that's your call. However, stop being rude and telling us bullshit like "I can't afford a swap, I am poor." Don't make dumb lying excuses. If you can afford $2715 for a jdm d15 vtec, you have just there also afforded a B16A or B18B1. The price is similer, the power putput a lot more, and the LS will blow the others away in torque. Now, if you want to build up the d15b7 or get the d15 vtec, that's fine. It's your money, and your car. But stop kidding yourself and giving us BS excuses like "I can't afford a swap. If you can afford to swap in a d15 vtec for $2715, you can afford to swap in a B-series as well. Either give us real reasons and don't make excuses, or get over it.
Old 12-24-2003, 06:21 PM
...thanks eckoman, youve just saved me a bunch of typing...
to 93dxon18s: eckoman, ricochet, and i have ALL been through the whole d-series engine thing and i know that we will all tell you the same thing. well, obviously. anyway...if youve got all these connections to free this and free that why dont you have connections to a guy who can get you a new engine, or a car dealer who can get you a new car...
18G Turbo - 8 Psi
GReddy EVO Catback
1995 Honda Civic LX
Bone Friggin' Stock
Old 12-24-2003, 07:15 PM
Honda God
Your welcome..I'm glad to know you were thinking the same thing...I just couldn't take his crap anymore, I've been reading and following the thread, and finaly was like...oh geez...can't afford a swap, but wants to pay $2715 for a d15 vtec? I don't care if it's jdm, vtec, or whatever....$2715 for a sohc d15 swap is absurd. And good point, since he has all these "free hook-ups" why the hell is he willing to get raped on the engine price? As for a "place where I can get a kit for $400 shipped," 93DXon18s, you get what you pay for with kits. It will have gaps, no fit correct, and require considerable molding to make it fit and look right, to elimnate the gaps, etc. That is assuming it's a fiberglass kit, if it's a urathane kit, you may have a stronger material, but you can't mold ureathane, your stuck with it, so if it fits like shit....second, your buddies dad may indeed be able to paint a car, and paint it well, but does he have the extensive knowledge needed to install a fiberglass kit and get it proper fitment, the knowlegde needed to mold it so it will fit correct? Not all people who do good body and paint work can do this...I am not saying he can't just food for a thought...now, you don't need to give me some long-ass answer about "how he can do this and that," as I am aware already that you most likely will say that regardless. And, to pheurton-skeurto, I agree with you, and good points. Where's the "free engine hook-up." All he's getting for that price is a "free I got raped on the charges."
Old 12-25-2003, 09:35 PM
first of all u retard, i never said i was going to or can afford the D15 vtec swap, i said thats what i really want tho. i dont have the money to swap any engine which is why i just want to try to build mine up. i never said i was poor i just simply stated i didnt have the money right now and couldnt get it quick enough to afford a swap. read the entire fucking post u stupid asshole, then try to crack on me and make dumbass remarks. second of all, $525 of the $2715 quote was for shipping cause its from Tokyo....it was like 1800 for the engine and the tranny was like a little more than 300. my friend said if i got the engine and the tranny and everything else i need for a swap, he would do it cause he owes me a favor anyways, bite my ass and dont even bother responding to this cause you're just gonna waste your time. learn to comprehend the words u read and then you'll realize that what i said wasnt what u said i said.
Cheap upgrades for a D15B7? srt4evah '88 - '91 Civic | CRX | Wagon | Shuttlee 34 09-10-2014 07:03 PM
What about NOS in a D15B7?? mmasse '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 13 05-12-2002 08:47 PM
Will D15B7 (95 DX) auto trans bolt to D16A1 block? Fishcat37 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 04-28-2002 02:40 AM
mini me for d15b7 Spinalfury '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 02-05-2002 01:33 PM
