Old 12-19-2001, 10:22 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Fujimi wheels on a Tamiya car?
I snapped the pin on one of the wheel of my Tamiya RX-7. Also my buddy bought me a Fujimi ITR Mugen. I noticed the wheels on the ITR have a hole while the Tamiya wheels have a pin. Are all Fujimi wheels like this? How would I fit some Fujimi wheels on Tamiya car?
Old 12-19-2001, 11:30 AM
awaken1973 awaken1973 is offline
Send a message via ICQ to awaken1973
I wouldn't say about all Fujimis but 2 my kits (Enthusiast serie) have very different wheel attachment mechanism: metallic bolts screwed thru the wheels to wheel hub
as for broken pin I glued it and than attached carefully
Old 12-19-2001, 11:32 AM
G-Forces's Avatar
Banned
I attached it back on too but it broke again. The break is right at the point the pin sit at teh brake rotor.
I think I'll put a brass pin in for more strength.
My original question still applies.
Old 12-19-2001, 01:04 PM
Guiddy's Avatar
Guiddy Guiddy is offline
Warren is the best man to ask!
I would put a rubber bush into the hole, and then super glue a pin into it.
The Fujimi enthusiast kits have a much different system, so that won't help!
Old 12-21-2001, 05:25 PM
primera man's Avatar
"P-Man"
I make up small bushes that fit inside the hole so that it is one sold round piece. This way it gives you plenty of area to glue.
Glue the bush inside the rim.
Then glue the rim to the brake disc using superglue.
The only thing you have to be careful of is getting the offset and camber correct.Takes a bit of mucking around getting right.
For the Tamiya one where you have broken the pin.......on some rims you can drill a small hole though the rim and use a small round piece glued into place and cut to length. Then fill the rim at the front with a small bit of putty and try and shape it back to what it looked like before you begain.
View All My Models Here.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
