Old 12-22-2003, 12:42 PM
imnotnotjoe imnotnotjoe is offline
Thumbs down Irratic RPMs.....help
while driving...usualy 30 to 40 mph....my RPMs will jump around irratically from 1000 Rpms to 3000 RPMs within a split second and jerk the car until i let off the gas.....1993 lumina euro (sensors?..tests?.....HELP!!) thanks
Old 12-22-2003, 11:25 PM
Euroguy026 Euroguy026 is offline
Check the car for codes, check Throttle Position Sensor, Idle Air Control motor, check sensors associated with tranny, all else fails, drive ur car on up to a GM or Chevy Dealer and have them check it out
Old 12-24-2003, 12:58 AM
Re: Irratic RPMs.....help
i have a code 42....something with the DIS module.....im confused about this car
Old 06-01-2004, 03:58 PM
jayvan700 jayvan700 is offline
Mine used to do that. It would run fine for a few miles, then, it was as if the engine was being turned off and on again over and over at a steady pace. Car would buck, revs would jump. Floor it and sometimes it would go and the Check Eng Light would come on. Checked the codes and had 2. MAP High (max high value) and MAP Low. Went to replace the MAP sensor, found the plug "falling" off. The tab was broken and a tie wrap was holding it. Replaced the tie wrap, the plug is now tight, it runs fine. Just a loose plug, poor electrical connections. (The dealer wanted to replce the fuel injectors.)
Old 06-02-2004, 02:26 AM
In a Previous Post, in an other thread, i messed with my idle screw and reset the ECM, and with tinkering with it, ive got it at where it idles at 1000 perfect...now dont ask me how but i removed the fuse for ECM, messed with the idle screw, turn it up a bit, and turned the car on. And Drove away Best Idle Relearn i ever did lol. I drove it for awhile, started to idle at 800 so i turned the screw up now its at 1000 so fiddle with it, maybe it i'll help. IT HELPED ME A BUNCH Good Luck
Beware My Euro May Be After U!
www.cardomain.com/id/euroguy026
The LUMINATOR LIVES On
Intimidator (#3 Nascar) + Lumina = Luminator
91 525i idles at 5000 RPM!!!! HELP!!!!! Metalmatt87 5 Series 0 11-13-2010 12:09 PM
k1500 rpm go up when driving garftree Sierra 2 08-22-2010 09:08 PM
Irratic Idle...Help vicsin42 3000GT/Stealth 8 11-10-2009 07:46 AM
94 Lumina Z34, Trying To Sell But Irratic Idle!!! Help Please!! BILLYBOBERENO Lumina 3 04-26-2004 10:04 PM
Hesitation at high rpm...help KaosR_Eclipse_GsT Off-Topic 11 11-17-2003 03:58 PM
