Old 12-22-2003, 12:28 PM
Craig440 Craig440 is offline
Changing Brake lights, need help
This is my first post and I realize that I am not as mechanically inclined as I thought. My wife has a brake light out on the passenger side. I thought this would be a trivial event to change the bulb. I realized after 20 minutes of fiddling and prying that I have no idea how to get access to the bulbs in the tail light assembly. Can anyone help me out here?
Thanks
97 Taurus Wagon
Old 12-23-2003, 12:01 AM
bigdinz's Avatar
bigdinz bigdinz is offline
I believe there are 3 bolts that have to be removed to remove the whole assembly. You will need a deep well socket (i forget what size).
Old 12-23-2003, 05:08 PM
I removed the 2 phillips screws exposed on the assembly when the rear hatch is opened, but have not seen any other fasteners that could be removed. Is removing the interior panel required to see the correct hardware for removing the lense for installing a bulb? I never thought a bulb change could turn into a project like this. I will look under the car and see if there is access to any fasteners I have not seen yet.
Thanks
Old 12-24-2003, 10:24 AM
bigdinz's Avatar
I do not have a wagon but yes, there is the cover material over the light assembly. On mine there were some pop out type fasteners I had to remove to get at the actual bolts. To remove my tail light assembly I had to remove 3 nuts on long bolts to remove the whole deal. I am not familiar with the wagon, sorry.
Old 01-17-2004, 07:06 PM
jaket jaket is offline
Taurus wagon only
there are two screws. The other point is held by a snap connector. Pry under the end of the lens/light assembly facing the front of the car. Be careful not to scratch the paint. IT is easier if you lift the back of the assemmbly out a little bit.
Old 04-28-2004, 09:38 PM
gldwingrdr gldwingrdr is offline
Thanks
Jaket had it right. After trying to figure it out I came in and found this web site. really was simple once I read his explination. Thanks.
92 geo metro convertable center brake light needed imlippy2 Metro 1 01-13-2011 05:58 PM
Help pls! Brake lights don't work :( fionathemystery How-To's and Walk-Through's 8 11-04-2010 09:21 AM
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 08:38 PM
Drivers Side Brake Light - Need Help Tricksta6 Renault 19 0 04-07-2007 12:37 PM
no brake lights-need help joker-z28 General Discussion 1 06-14-2005 02:39 PM
