Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-22-2003, 02:18 AM
mrchris1979 mrchris1979 is offline
SOHC ZC/VTEC and NOS
So this is my project that I'm currently doing for my 88 CRX SI. With the SOHC ZC block and the D16Y8 head I did my research and the compression will be about 11.5 to 12. Right now the vtec head is not on the block. The SOHC ZC head/block compression is about 10.0 which is running on stock fuel injectors and fuel pump with an adjustable regulator set at 55 PSI. My a/f gauge says the car is running perfect. Once I put the vtec head on, I probably have to upgrade to higher flowing injectors. I don't want the pain of replacing the stock fuel pump so what is the highest flowing injectors I can use to accomidate the higher compression and an occasional 50 shot of wet NOS (not sure what brand yet) using the stock fuel pump ? (if possible)
Jdm Sohc Zc Vtec!!!! talonpunk831 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 02-05-2006 03:44 AM
Need Help With SOHC ZC Vtec!! twiztedcfx Let's get Technical! 6 06-24-2005 10:30 AM
ecu for sohc zc vtec bulldawg151 Let's get Technical! 5 03-03-2004 07:21 PM
sohc zc vtec bulldawg151 Let's get Technical! 1 02-17-2004 12:56 PM
SOHC ZC/VTEC and NOS mrchris1979 Engineering/ Technical 2 12-23-2003 09:50 PM
