Old 12-20-2003, 07:18 PM
95mr2's Avatar
95mr2 95mr2 is offline
which cluster do I use????
which cluster will I want to use in my 91 civic hatch if I swap a d16z6 motor into it? Can I use a 92-95 si cluster if not what one do I need to get? I want a tach and everything. thanks for the info in advance.
retired name
Old 12-20-2003, 07:32 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: which cluster do I use????
i justed use my civic si cluster from 88-91. the redline is a lil higher on a z6 then the gauge show where redline starts, but i dont care. you could try wiring the 92-95 si/ex cluster in if you can figure out what wire goes where and you convert to a electric vss.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 12-20-2003, 07:43 PM
95mr2's Avatar
Yea I did that with my b16 so I might as well go for it. lol I'd rather have the electric vss an stuff with the correct cluster if it will fit... do you know if it'll fit??? You at work GTA?
retired name
Old 12-20-2003, 07:47 PM
95mr2's Avatar
or yanno what honestly I'll probably just buy the cable to hydro conversion kit and use the hydro tranny with the electronic vss etc.
retired name
Old 12-20-2003, 08:03 PM
GTA's Avatar
GTA GTA is offline
Whee..
the cable to hydro kit was for b-series only as far as i know. you'd have to figure out a way to mount the 5th gen cluster..and yes im at work.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
1993 base cluster to UB3 Upgrade?? Laprecio Cutlass Series 0 09-15-2009 12:10 AM
2001 Passat Instrument Cluster Ryannables '97+ 1 06-15-2009 09:10 PM
'99 GP/GT Instrument Cluster Problem USARet1995 Grand Prix 6 04-21-2009 09:47 PM
Which cars used carbon fibre first? racer917 Car Modeling 14 09-20-2004 07:11 PM
