Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-20-2003, 01:44 PM
peeryje peeryje is offline
'96 Aurora radiator
Hello
I seem to have a coolant leak on the passanger side. It looks like it is from the top fan mounting bolt. Anyone seen this before? Is there an o-ring or seal of any type here?
Thanks
Jack
Old 12-20-2003, 02:51 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: '96 Aurora radiator
No, there's just a boss molded in. Are you sure there's not a crack around the oil cooler line where it threads into the tank? This is a common failure area.
Quality isn't expensive, it's priceless.
Old 01-09-2004, 01:41 AM
jessb45 jessb45 is offline
Unhappy
This is a VERY common problem with the Aurora. In fact, I had the exact same problem myself. The coolant looks like it is leaking from the bolt or the area right around the hose clip. However, if you examine this very closely you will see a small crack. I had to purchas a new radiator. I could not find one without plastic tanks. However, I found a good aftermarket radiator here with a great warranty:
http://www.radiatorexpress.com/produ...aia_id=1216965
This one has a lifetime warranty and you can purchase a lifetime labor gaurantee as well for $10 (they will reimburse you to have a mechanic of your choice install the new one). The radiator costs $229 from them. For the gaurantee it carries I consider it worth it. It is not too much trouble to install yourself. I installed mine in less than 3 hours. That was the best overall deal I could find and the radiator itself was about 50% thicker than the OEM one.
Old 05-12-2004, 02:12 AM
eoc101 eoc101 is offline
If u need a radiator or anything for ur Aurora for that matter, let me know. I have parts and i have the radiator ur needing that's in perfect condition from a 96 Aurora
steering wheel lamps in '96 aurora 96blackbeauty Aurora 0 07-05-2004 06:21 PM
'96 Aurora - Optional Tire Size Spinman Aurora 3 03-27-2004 11:19 PM
'96 Aurora A/C Diagnostics Mode? Spinman Aurora 2 03-27-2004 10:19 PM
'96 Aurora engine miss DuramaxDiesel1001 Aurora 6 03-14-2004 12:22 PM
delay windshield wiper '96 aurora peeryje Aurora 1 01-14-2004 12:40 PM
