Go Back   Automotive Forums Car Chat > Nissan > Nissan 350Z/370Z | Infiniti G35/G37 Coupe
Nissan 350Z/370Z | Infiniti G35/G37 Coupe Includes the VQ35DE, VQ37VHR - Z33 and Z34.
Old 12-20-2003, 01:02 AM
vectorz vectorz is offline
HELP! Rim vibrations!
Hi, I have a 1999 Mitsubishi Galant DE, and I wanted a cheap upgrade on the rims, so I researched and found that the 350z stock 17" rims match my lug pattern, and the offset was very little. So I got ahold of the 350z stock rims and put on some new Kumho Ecsta 711 tires size 225/45/17 - per recommendation of tires.com, tirerack.com, and the tire servicers (America's Tires).
After putting them on, I get major vibration going over 50mph. I've narrowed it down to have something to do w/ the lugs. The lugs were tightened by the service technician to about 80lb/foot. I tried tightening them to 90lb/ft and it got better but not good enough. I then went to 100lb/ft and now it is A LOT better but not gone. The vibration doesn't start until 70mph, but it is still significant. I don't want to tighten it any further because I'm scared it might screw the wheel studs (I've broken many wheel studs in the past from overtightening).
I noticed from the old lug nuts that the wheel studs for 350z is thicker. You guys think this is the problem? Or should I torque it even tighter.. say 110lb/ft? Will this cause any issues? Any help would be MUCH appreciated!!
Old 12-22-2003, 02:19 AM
rizzspeed's Avatar
rizzspeed rizzspeed is offline
Send a message via AIM to rizzspeed
Re: HELP! Rim vibrations!
The wheel's probably not 'hugging' the hub of your car correctly or if at all. The hub helps to center the wheel on it and to take some of the vehicles weight off the lugs. You might need a new hub ring on the center of the wheel.
Another thought.....after changing to larger wheels than stock, did you do an alignment? Try and have the wheels rebalanced as well.
Old 05-04-2004, 09:10 PM
khfromhb khfromhb is offline
get z lugs and have your wheels balanced
Old 05-16-2004, 12:34 PM
Grim13 Grim13 is offline
yeah, it sounds like your wheels needs balancing. You should always get it done when you get new rims or wheels.. or both.
Does anyone know what type of rim this is? just a question Tires and Wheels 1 11-29-2010 07:26 PM
Help! New rims vibration.. vectorz Galant 6 05-25-2005 09:50 AM
pLEasE HELP! Engine vibrates!Appreciate any help poisonko Accord/TSX/Accord Hybrid 0 05-04-2004 12:07 PM
Need HELP Please! New rim vibrations vectorz Tires and Wheels 1 12-22-2003 11:00 AM
