Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-19-2003, 10:22 PM
triplettsford triplettsford is offline
Angry Back Doors will not open from the inside!!!
What is the matter with my truck? The back doors will not open from the inside! What is up with that? The child safety feature on both doors are in the "unlocked" position! Anyone have any problems with this? Anyone have a solution! PLEASE HELP!
KT
Old 12-20-2003, 05:56 PM
re3 re3 is offline
Re: Back Doors will not open from the inside!!!
i dont know man but my doors wont open either .
Old 12-22-2003, 04:46 PM
****5.4**** ****5.4**** is offline
My rear driver side door has that problem. I took the door handle assembly apart and found that there was a piece of plastic that broke off which keeps the handle from going back and forth. All I have to do is go and get a new handle assembly from Ford and it will be solved, but I'm too lazy. Just take the door panel off and play around with it. It should only take like half an hour to find out if this is the problem.
Old 12-24-2003, 03:35 PM
Tugger Tugger is offline
The problem is in the interior door handle. Take the door panel off and then there are 2 screws that hold the black handle on. Be careful to not bend the rod when you take the rod off the back. Turn the handle over and look at the plastic gear that moves when you pull the handle. The part that always breaks is the lowest gear tooth that you can see. Take a flashlight and you'll be able to see if there is a break. These parts are famous for breaking all the time and are pretty cheap to replace yourself. Tom
One more thing.....if anyone has an Eddie Bauer Ford Explorer and needs to replace the Blower motor resistor, this part is different from regular explorers due to the Climate control. Ford had to redesign this part since the original OEM part goes bad. They cost approx. 110.00. Make sure your parts dealer understands this is for the Eddie Bauer Edition or else the one you get won't work
Old 12-29-2003, 10:18 AM
Opera House Opera House is offline
The inside door handle may have snaped a tooth but that wasn't the initial problem. I bought a 97 with that problem and the handle had snapped the tooth. It still wouldn't work with a new one. I pumped a bunch of oil into the door latch mech. Lightly worked the handle about 30 times and then it started working again. The door handle pushes on a thin steel wire. Any resistance from the latch and the wire just bends. Forcing handle only breaks the teeth. So the real problem is dried out grease and corrosion.
Old 02-02-2004, 01:57 PM
tpwhec716 tpwhec716 is offline
Same here...have replaced the driver side back door inside handle twice. Walked up to the Ford parts counter with the broken one in my hand and all he asked was ..."right or left side". He even knew the part number without looking it up. don't know of any solution until it is redesigned and Ford isn't going to do that now.....
Passenger side door will not open from the outside SuperSaiyan Lumina APV 2 12-23-2008 02:41 PM
1999 Cavalier back doors will not open, not power locks missdiane Cavalier Problem Diagnosis 1 10-02-2008 12:04 PM
1989 Passenger Door Will Not Open From Outside palehorse MPV 2 07-20-2005 02:42 PM
HELP!!! driver side back door will not open!!! Ditto_Geek Camry/Camry Hybrid/Vista 2 11-15-2004 08:16 AM
2001 Maxima rear door will not open from inside or outside rwig Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 08-30-2004 08:34 AM
