Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 12-19-2003, 07:57 AM
Hybrid1990crx's Avatar
Replacing Waterpump on 98 Acheiva
The waterpump on my g/f's car just took a shit and I'm wondering how hard it is to replace it. Its a 98 Acheiva. What tools will it require me to have, and what is the process? What would you guys rate this in difficulty from 1-10? 1 being easier and 10 being the hardest. Thanks guys.
Old 12-19-2003, 08:10 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Replacing Waterpump on 98 Acheiva
What engine does it have?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-19-2003, 12:00 PM
Its the 3100 SFI v6. I don't know much about gm's at all. As you can tell, im a honda kid.
Old 12-19-2003, 12:16 PM
GMMerlin's Avatar
I know stuff
Re: Re: Replacing Waterpump on 98 Acheiva
Sorry to hear that...you will out grow it........
Here is the information as you requested.
Water Pump Replacement - Auxiliary 3.1L
Removal Procedure
Notice
When adding coolant, use DEX-COOLŪ coolant. If silicated coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will require change sooner-at 50 000 km (30,000 mi) or 24 months.
Drain and recover the cooling system. Refer to Draining and Filling Cooling System .
Remove the drive belt.
Remove the coolant pump pulley bolts.
Remove the coolant pump pulley.
Remove the coolant pump attaching bolts.
Remove the coolant pump.
Clean the coolant pump and the sealing surfaces.
Installation Procedure
Using a new gasket, install the coolant pump.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the bolts. Tighten
Tighten the coolant pump bolts to 10 N·m (89 lb in).
Install the coolant pump pulley.
Install the drive belt.
Refill the cooling system. Refer to Draining and Filling Cooling System
Inspect for leaks.
GM WCT
PM Me for details
Old 12-19-2003, 04:07 PM
Yeah that helps alot. But that serpentine belt confuses the crap out of me. I looked down to see where the bolt is for the spring tentioner and it looks like it is going to be a bitch to even get to it with a breaker bar? The serpentine is really what is making me not want to do this. I don't understand why I even have to take the fucking off, since the waterpump pulley rides on the outside of the belt. The shop near my house said it had to come off, and even be replaced because of the coolant that got on it. Couldn't I just take it to the car wash and use the degreaser blower on it?
Old 12-19-2003, 05:32 PM
GMMerlin's Avatar
I know stuff
All you are going to do is move the tensioner (it is spring loaded) to remove and reinstall the belt.
Spend the extra bucks and replace the belt
GM WCT
PM Me for details
Replacing Waterpump phewop118 Intrigue 4 12-18-2008 09:42 PM
replace waterpump yes or no fathertime769 S-10 7 11-06-2005 08:17 PM
replace waterpump on 96 monte kris2qt2bstr8 Monte Carlo 3 03-01-2005 06:53 PM
Replacing waterpump Liberato Aurora 0 02-10-2005 10:35 PM
How difficult is it to replace waterpump kstrine Aurora 8 11-04-2004 04:43 PM
