Old 12-18-2003, 09:27 PM
2of9 2of9 is offline
Evo 8's Turbo?
Hey friends...i was just in school in today and was thinking. Is the Turbo in the Evo 8 the same as the other Eclipse/Talon AWD's? OR is the engine in the Evo just a bit more modified? just confused there...thanks...
Silver_GTR34
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-19-2003, 09:30 PM
1320B4U 1320B4U is offline
I believe it is a B16g sized turbo. I think overseas where they get the 'real' EVO's (more power/wicked AWD systems, available stripped models) it also has titanium turbine blades or some other exotic material. The engine is a 7-bolt with hollow cams, forged internals-I think the C/R is 8.8:1 and its pushing 19lbs through a front mount from the factory.
1991 Eclipse GSX
2001 Yamaha R6
Old 12-20-2003, 09:02 PM
hosler hosler is offline
Re: Evo 8's Turbo?
the evo 8 turbo's are reverse scroll turbo's meaning they spin in the opposite direction as most turbo's. It could be done, but it would not be worth it.
Old 12-21-2003, 04:27 PM
NeonblueEclipse NeonblueEclipse is offline
Send a message via MSN to NeonblueEclipse
Re: Evo 8's Turbo?
jussa ?
if the turbines spinning in to opisite direction, wont it pull or push air out of the engine ???
Dustin
GSX baby!!! ALL THA WAY
Old 12-22-2003, 02:34 AM
It's a twin-scroll turbo, which means the turbo's exhaust inlet is split into two seperate inlets which spools the turbo faster/more responsive by means of the firing order/exhaust pulses of the engine. So the 4-exhaust manifold runners pulse into the two seperate inlets on the turbine, or something like that
And comparing the EVO 4G63 to the DSM 4G63 it has a lighter valvetrain, made to rev quicker/more responsive, and it has forged rods/pistons- what you do to a DSM motor when you want serious reliable power out of it(20g+, 350+). The 2JZ has forged rods from the factory and is naturally well balanced as it is an inline 6, but are the pistons forged?
1991 Eclipse GSX
2001 Yamaha R6
Evo 8's Cams & MAF scottsee Off-Topic 6 03-24-2005 10:13 PM
EVO vs. Turbo E36 M3 3000ways Car Videos 0 05-10-2004 08:24 PM
Evo 16g Turbo Questions [once again] Afrokid Off-Topic 16 03-18-2004 04:26 PM
16G vs. Evo III Turbo Afrokid Off-Topic 8 11-28-2003 10:04 PM
Evo Vii Turbo Type galant Lancer 1 11-29-2002 04:05 PM
