Old 12-18-2003, 08:23 PM
JTS03COBRA JTS03COBRA is offline
1995 S10 Blazer engine & stuff...
I have a buddy who's reinstalling the original W code engine (been rebuilt) back into his sister's '95 S10 Blazer 4x4. The ECM is under the hood. I was wondering if anyone can give insight on what all that'll need to be done before start up is attempted? Things like: proper distributor install, speed to run the engine at once it starts, etc. Does anyone have a vacuum diagram of the '95 4.3 available? Is the control system OBD I or OBD II? Also what does cpi mean?
Regards,
Joe
2003 Mustang SVT Cobra, black, stock, 12K miles (for sale $27K/obo).
Click here to see pics of my '03 Cobra
12.45 @ 114 mph
1997 Pontiac Grand Prix GTP
14.46 @ 95 mph
Old 01-29-2004, 03:21 PM
eschapiro eschapiro is offline
Re: 1995 S10 Blazer engine & stuff...
CPI stands for Central Port Injection.
This engine was promoted as OBD-II, and 75% of the time behaves like that, but it is NOT 100% OBD-II Compliant, many scanners do not read it's codes.
Old 02-01-2004, 08:39 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: 1995 S10 Blazer engine & stuff...
Only if the ECM is under the dash... If the ECM is in the hood, then it's ODBII compliant... The one under the dash is the majorly farked ODBI1.5
Old 02-01-2004, 08:46 AM
rlith's Avatar
Regards,
Joe
The big pain in the ass is the distributor... With your buddy's it's a locked distributor... You need to make sure it's TDC with the mark on the balancer being the one to the left of the DOT. If it doesn't immediately start up, then you are 180 out...When we did mine, it took 4 tries with it properly lined up to drop in the distriubutor. If you use the line up method on the rotor to wire one (which is actually 8 o'clock) make sure you're just slightly ahead of it... Again, we had to drop it in 4 times...:P After that no timing is necessary. If his engine is already out, it would also be a good time to replace the freeze plugs...Use brass.... That way you don't have to worry about it again. Also be sure to clean the egr ports and the egr itself. Use a small screw driver and spray with air (be sure you cover the valley with a rag or something if you're lower intake is off. Do NOT use gaskets for the exaust manifolds (unless you are putting on headers). They are not designed to be used with gaskets...Metal to Metal only.
New freeze plugs (rest of the truck can be seen at www.pghconsulting.net/teal
Old 02-02-2004, 10:47 AM
Whew, that was hard to read. I appreciate the info. I think I follow you correctly, so to line up the crank to the distributor correctly, you set some kind of marker on the crank pulley in line to some kind of dot on the (timing cover?) Then look at the position of the distributor rotor to be sure it's at the 8 o'clock position which should be slightly ahead of the #1 spark plug wire plug-in on the distributor cap? Of course he should be sure that the # one cylinder is on the compression stroke, right? If you want you can clarify anything. Anyhoo, I'll relay this to my buddy and see what comes up. Right now it's too cold/snowy/icy to do anything with it.
Old 02-02-2004, 10:57 AM
rlith's Avatar
No, you've got it, but you line up the mark with the timing cover before trying to put the distributor in, then you line up the distributor. And yes, it should be on the compression stroke, but if it's not, it simply won't start and you'll know that you're 180 out.
Old 02-02-2004, 11:00 AM
Again, thanks a ton man!!!!!! I'll try to update if he tries anything with it.
Old 02-02-2004, 11:05 AM
rlith's Avatar
No prob... Keep us abreast of the situation
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 10:35 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 10:11 AM
Can't get fuel filter off of 1995 S10 Blazer bobby0965 Blazer 11 12-04-2005 10:51 AM
1995 s10 blazer keyless entry smoore34 Audio/Security 0 01-21-2004 08:30 PM
starter from 86 s10 blazer fit & work in 88 s10 blazer help pleEASE!!!! juzdose S-10 1 12-20-2003 07:36 PM
