Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-16-2003, 10:45 PM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
Head Gasket Replacement
Hello all... I was just wondering how to replace a head gasket in a 1992 240sx ka24de engine.. I have a chilton book which is junk and dosnt tell me crap about just replaceing head gasket.. What is involved? Do I have to remove cams? ect.. Any heads up and some detaled info would be apreciative because I got to get it done in a 4 days... Should i just take it in to get fixed?
thanks
Old 12-17-2003, 03:12 AM
stealthj's Avatar
stealthj stealthj is offline
Send a message via AIM to stealthj
Re: Head Gasket Replacement
i would take it in, butmost places charge around 500 bux or sometrhing
cuz they get their shit out of a book that sayd it takes 11 hours to replace it
id say throw it out ..... and did u blow it yourself?
u need to basically take off the valve cover
remove cams, and lets see i forgot, i did this like a month ago....
there are like a million SCREWS
PLEASE LABEL EVERYTHING IN SEPARATE BAGS -U WONT REGRET IT
but anyways, the head comes off with intake manifold..... so u need to remove screws screws and screws,,,,,, i dunno if u can do it in 4 days
BANNED
Old 12-17-2003, 10:05 AM
yup
yup i blew it my self! thats what i get for hotroding.... well im prob gonna take it in or get a new engine and drop it in. im already at 12000 miles so the engine might be going. Any other sugetions?
Old 12-17-2003, 11:07 AM
publicenemy137's Avatar
publicenemy137 publicenemy137 is offline
Send a message via MSN to publicenemy137
my mechanic charged only $70 to replace mine, he charged really cheap though. I had all this oil on my spark plugs so he had to drain that too, though he gave me a big discount
Old 12-17-2003, 01:20 PM
stealthj's Avatar
Re: Re: Head Gasket Replacement
time to srDET your self!
BANNED
Old 12-17-2003, 01:21 PM
spitz7985 spitz7985 is offline
Send a message via AIM to spitz7985
$70??? are you sure he didn't replace the valve cover gasket?
Old 12-17-2003, 01:29 PM
stealthj's Avatar
SHIT I JUST SAW THAT
YOUR TRIPPIN NO ONE WOULD REPLACE A HEAD GASKT FOR 70$
HELL NO , ITS THE PAIN IN THE ASS, POEPL CHARGE LIKE 400$ JUST TO PUT BACK TOGETHER
MAYBE ITS VALVE COVER GASKET SERIOUSLY
YOUR TRIPPPPPIINNN
BANNED
Old 12-17-2003, 01:44 PM
gunluvS14's Avatar
gunluvS14 gunluvS14 is offline
$70 does sound little bit too low
but anyway, not much of tips from me. Follow that Manual, although its not the Factory Service Manual, it still helps out a good bit.
All i can say is don't unbolt the intake manifold, keep it on the head(u will know why if u take it off), unhook that EGR tubing that connect your exhaust manifold with your Intake Mani. at the back of the engine. Unbolt exhaust manifold.. take off valve cover, remove cams, and head bolts. Reserve is everything when u install and make sure everything is torque back to factory spec.
One thing its very important is, when you unbolt the cam journal cap or the cylinder head bolt, ALWAYS work your way from the outside to inside, also cris-cross.
then when you put it back together, ALWAYS work from the inside back to the outside. Also when u torque the head down, let say it should be back to 95lb/ft of torque; torqued it down to 50lb/ft first from inside to outside.. then take it ALL off again, torque it to 50lb/ft stop, then 70lb/ft, then finally to 95lb/ft(I am just making an example, that's not the torque spec)...
But yea, do it youself because it will cost a decent amount of money to replace them at any shop. but if you are not comfortable with it, I guess you might have to let the professional to handle it then.
good luck
Old 12-17-2003, 05:22 PM
yup
70 bucks? no way i got a quote for 500... Dam im lost on what to do!
Old 12-17-2003, 10:14 PM
no it was the whole gasket, reason why it was leaking to where my spark plugs were. My mechanic who used to live with us hooks us up with real cheap labor. When I first got maintainance done on my car, he changed the breakpads, hardware, rotors, ops, belts, wipers, and tension rods all for $100 labor.
For the gasket though it was $70 b/c that was his mistake in breaking it so I guess he just charged really cheap. He definetly was not happy about replacing it, u could tell on the look on his face that it was going to be a bitch to do
Old 12-18-2003, 09:57 AM
gunluvS14's Avatar
dude, from what I read you said oil is leaking into your sparkplug hole, right?
then what he replaced is not headgasket then. It just a reuseable rubber gasket that go between the valve cover and the sparkplugs gallery right in between 2 cams.
Old 12-18-2003, 10:08 AM
^ oh ok, yeah i'm no mechanic lol
Is that hard to do?? He had to drain the oil from the sparkplugs gallery and replace that rubber gasket
Old 12-18-2003, 10:26 AM
gunluvS14's Avatar
nope.. 12 bolts on the valve cover. Use suction tool to get most of the motor oil out of the sparkplug gallery... replace that rubber gasket, put the valve cover back in place. Shouldn't take more than 15 mins and should'n't cost $70 to do it, unless he did some touch up for you for something else.
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 03:56 AM
Intake gasket or head gasket?? mandymae104 Century 3 07-10-2009 09:31 AM
'92 SC - head gasket - replace both head gaskets? kaje71 Thunderbird 2 09-05-2008 05:10 PM
head gasket replacement? nwander Lumina 2 11-13-2004 10:40 PM
1992 Explorer head gasket replacement jmartin7 Explorer | Explorer Sport Trac 1 11-19-2003 10:20 AM
