Old 12-16-2003, 05:36 PM
94gpse 94gpse is offline
Water Pump Location
Does anyone know where the water pump on a 94' grand prix 3100 v6 is?????????? Also, should i replace the pump myself or take it to a dealer???? Any help is apprecieated.
Old 12-16-2003, 10:16 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Water Pump Location
Your water pump is driven by the serp belt! Look at the top front of your engine right under the luittle plastic piece with the belt routing picture on it.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 12-17-2003, 02:43 PM
Thanks that will help me major. The car is a 94' gp 2 dr. with a 3100 v6. Do you know how much the dealer would charge to replace a water pump????? Thank again
Old 12-17-2003, 02:45 PM
I forgot the car has a weird noise coming from the engine and the heater doesn't heat up very good. Thanks again
Old 12-18-2003, 07:43 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
To tell you the truth, if you are not certain that water pump is the problem. IS better to get it inspected by someone that has a little more experince than you. Could be a split hose or leaky radiator.
Does the temp gauge is hotter than normal for an instance?
Old 12-19-2003, 08:15 PM
The temp has a normal reading of about 210. Thanks again
Old 12-21-2003, 09:23 PM
kilroypr's Avatar
210 is not normal. 195 is normal. Check for leaks
If there are none then check the pumpo
Old 04-27-2004, 01:00 AM
mr2racer mr2racer is offline
Send a message via AIM to mr2racer Send a message via Yahoo to mr2racer
I have to replace my friends water pump on her 94' Grand Prix V6 tommorrow. Does anyone have any advice at all? I have never really worked on her car, but know a lot about mechanics in general.
Where is windshield water pump located? islandman7 900 0 11-18-2010 03:59 PM
2002 3.5 water pump location zephram22 Aurora 3 10-19-2005 06:45 AM
water pump location... vdubclub13 Jetta/Vento/Bora 0 05-30-2005 08:12 PM
Where Exactly Is The Water Pump Located FRANCO301 Aurora 7 03-24-2004 04:25 AM
1991 Acura Integra ???Where is the water pump located ;-) kde Integra 2 08-15-2003 10:00 PM
